Car runs needs exhaust finished and a tune. Do not recommend driving the car without it being finished.
$2500 firm for everything
Fresh 20v Blacktop Block with Oil Squirters
4afe Head
HKS 2mm Headgasket
4AGZE Pistons
4AGZE Rods
20v Blacktop Crank
20v Blacktop Flywheel
ACT 4 Puck Clutch
Techno Tuning Lightweight Crank Pulley
Turbo Supra Injectors 440cc
ARP rod, main, flywheel and head studs
HKS Oil Filter
TOGA Race Bearings Main and Rod
T04E Turbo
Tial 38mm wastegate
Custom Turbo Stainless steel Manifold
Custom 2in Intercooler Piping
Apexi Intercooler
Greddy Type RS BOV
Oil catch can installed yet
Tomei Fuel pressure regulator with Tomei adapter for fuel rail
TOGA HV Oil Pump
Walbro 255 Fuel Pump
OBX-R Radiator Hoses
VMS Racing 10mm Spark plug wires
OBX High Performance Racing Iridium Spark Plugs
Aem tru boost and Wideband
STRI Oil Pressure Gauge
Short Shifter
3in Stainless Steel downpipe
Apexi SAFC II
Semi wire tuck
Advan replicas good tires
Rear Disk Conversion
Custom shaved valve cover with rouge status theme
RedBull Boost Gauge Custom
Gauge Cluster with Tach
Racing steering wheel with quick release
Brand New Battery with Warranty
Arev 1'' wheel spacers
New Rear Main Seal
New Timing Gear and Crank Bolt
New Timing Gear Covers
New Toyota Timing Belt
New Timing Belt Tensioner
New Water Pump
All New Gaskets
All New Belts
All Royal Purple Fluids
Most all new nuts and bolts
Viper Alarm System with GPS Tracking Not installed yet
every bolt is torqued to spec;)
Again, in order for me to part out the car I must find a buyer for the motor. Feel free to ask any questions. Thanks for veiwing
