FOR SALE:
-4AGE 7rib block built with 4agze rods and *NEW* 8:0 ceramic coated and notched to clear oil squirters, ACL racing bearings for crank and rods, ARP rod studs, crank has been polished, block and crank has been hot tanked and Magna Fluxed.
***SHORT BLOCK SOLD!!!***
-*NEW* full engine gasket kit $150.00
-RWD Conversion kit SOLD
-Distributor plug uses the distributor O-Ring $25.00
-1jztte 440cc injectors SOLD
-Cast T25 turbo manifold SOLD
-Ford EDIS 4 ignition kit complete. SOLD
-All the brackets for the 20v motor, Power steering pump and bracket, Alternator bracket, AC bracket $80.00 for everything
-4AGE 20v Black Top Wiring harness $200.00
-4AGE 20v Black Top Head SOLD
-ITBs SOLD
-All the sensors SOLD
-3x T50 transmissions Only 1 bellhousing $OLD
-4AGZE Flywheel clutch and pressure plate $50.00
-4AGE flywheel $20.00
-SR5 rear end and 4 links $100.00 for the rear end with all the brackets $40.00 for the 4 links
-Rear shocks maybe 1000km on them $30.00 for the set
-various parts for 16v such as Late Big port cams 2x sets $OLD
-16v Distributors $OLD
-16v Plenum $OLD
-a bunch of 16v valves, buckets and cam shims $OLD
If you are interested in any of the items I have for sale please post on thread that you emailed me and then inquire price through email. Thank you.
evan66@gmail.com
