FS new 82MM 10.5 to 1 Wiseco pistons
Davegt27
Postby Davegt27 » Wed Mar 26, 2014 8:25 pm
I bought a set of trick pistons off Yahoo Japan when I got the pistons I sent one to Wiseco with the request "make some like these"
This is what I received, I bought two sets so the other set is in my race motor
New 82MM forged Wiseco Pistons CR 10.5 to 1 weight 289.7 to 290.3 grams (complete set of 4)
Price $550 firm
buyer pays shipping
David
Dasgtnut27@aol.com
Davegt27 Code One Racing
Davegt27
Re: FS new 82MM 10.5 to 1 Wiseco pistons
Postby Davegt27 » Sun May 04, 2014 10:02 pm
still for sale
gekishibu86
Postby gekishibu86 » Wed May 07, 2014 10:55 am
Could you please elaborate what is so trick about this pistons and does it comes with rings and pins? Thanks.
Davegt27
Postby Davegt27 » Fri May 23, 2014 9:59 am
Sorry for the late reply yes the pistons come with pins and rings
For best power the pistons will come up above deck to best control piston squish
Wt. of piston #1 is 290.22 lock = 1.47 pin = 75.83 ring 21.93
Top ring is 1mm 2nd is 1.2mm oil is 2.8mm
If you can find some better ones for this price let me know
David
Postby oldeskewltoy » Fri May 23, 2014 2:49 pm
Do you have the specification sheet? What is the comp height? bore is 82mm, also what is the dome volume?
Davegt27
Postby Davegt27 » Sun May 25, 2014 1:51 pm
Yes 82 mm bore it has all the paper work (spec sheet)
What is the comp height? Bore is 82mm, also what is the dome volume?
Why do want to know this?
David
Postby oldeskewltoy » Sun May 25, 2014 3:17 pm
Davegt27 wrote:Yes 82 mm bore it has all the paper work (spec sheet)
David
1) to know how much you can machine the block deck... 2) to properly calculate compression ratio (what if buyer uses thinner head gasket... and/or cuts the head to reduce chamber volume... how will he know the new compression ratio if he doesn't have these specifications
Davegt27
Postby Davegt27 » Sun May 25, 2014 5:52 pm
I see all that information is on the spec sheet that will come with the pistons it will also have
Depth from timing edge, valve angle, pocket diameter
Davegt27
ss9338
Postby ss9338 » Sun Jun 22, 2014 6:53 pm
Would these be good for a small t3 turbo? My tuner says the turbo will max out at 350-375. I am running hks 8.5 lift 256/264 cams with stock valves. will my head work with these? and are they 20mm wrist pins?
Davegt27
Postby Davegt27 » Fri Jun 27, 2014 3:56 pm
I don't think so get some GZ pistons you would be set (oh GZ pistons are the stock super charged pistons)
Take the short block to the machine shop explain to him what you want give him the piston pn's so he can order them for you
HTH's
Davegt27
Postby Davegt27 » Sun Nov 09, 2014 5:34 pm
these are still for sale
