FS: 4AGE engine parts & a few AE86 parts
davew7
Postby davew7 » Wed Sep 17, 2014 7:19 am
All items for a Big port engine
(4) blue top big port injectors $15 Sold
GTS flywheel and pressure plate $10 Sold
(1) AE86 engine mount [1], in like new condition $20
1 pr Big port cams gears $5
Pr Big port cams $20
Cam covers, Black wrinkle painted W/ all numbers and letters shaved off Sold
[includes fill cap, gaskets and gold colored center plug cover] Sold
cold start injector and fuel line $5
Both Hi & Lo fuel pressure regulators $10 Sold
Oil pump $10
Oil cooler adaptor/filter for engine block $10
Polish fuel rail including spacers & polished Stainless mounting hardware $20 Sold
(4) low compression pistons , 18mm pin, std bore, w/ aprox 20K miles $10
TVIS W/hoses and check valve $10 Sold
Plastic 3 pc front Cam belt cover & rear Steel plate W/ hdw $10 Sold
Stock Rear GTS stab bar $10 Sold
Emission canister $5
GTS T-50 bellhousing $40 Sold
T-50 short shift kit W/ spacer and extend shift lever $15 Sold
AW11 trans cover plate & pressure plate $5
AW-11 exhaust "Y" pipe W/O flex joint $5
AW-11 Alternator mounting & adjustment bracket $5
Lots of 4AGE sensors, brackets, smaller parts, & relays; send request.
Can supply photos on request
Contact me at mtwhitt@sbcglobal.net
Shipping cost from Michigan, please include your Zip codes when contacting.
Thanx Dave
DanR2
Re: FS: 4AGE engine parts & a few AE86 parts
Postby DanR2 » Wed Jul 22, 2015 7:56 pm
I am looking for rear bumper brackets . Or the complete
Alex170984
Postby Alex170984 » Thu Jul 23, 2015 4:11 am
You wouldn't happen to have a 42mm crankshaft would you?
davew7
Postby davew7 » Fri Jul 24, 2015 4:53 am
Sorry no crankshaft. I will up date this list of items. Done
dayyou
Postby dayyou » Mon Sep 21, 2015 11:56 am
Would you happen to have a picture of that aw11 y pipes condition? is it mk1a or b
davew7
Postby davew7 » Tue Sep 22, 2015 9:16 am
PM sent to dayyou.
