Mostly Big Port 4AGE parts
davew7
Postby davew7 » Tue Oct 14, 2014 6:15 am
These parts left for AE86 & MR-2
4AGE Big Port Cam $12, pair for $20
GTS RWD engine mount [like new] $15
Cold start injector W/ HDW and fuel line $10
Oil pump W/inlet tube & Rear retainer Both W/ new seals $10
MR-2 Engine block Oil cooler adaptor $10
T-50 , 2nd motion Gear shafts [good for parts only] $10
T-50 stock shift lever with trans attach bracket $10
Emission vapor canister $5
O2 sensor W/ gasket and HDW $5
Other small MR-2 & EA86 parts, brackets, coolant in/outlets, Temp sensors for electrical and vacuum, and several relays. (Send needs)
Can supply photos on request
Will quote shipping from 48178, if you include your Zip code when contacting me at mtwhitt@sbcglobal.net
oldskoolte72
Re: Mostly Big Port 4AGE parts
Postby oldskoolte72 » Wed Oct 15, 2014 1:49 pm
Emailed
oldskoolte72
Postby oldskoolte72 » Tue Oct 21, 2014 4:00 pm
Good seller ! Received item exactly as described and shipping was fast also
Driftslut
Postby Driftslut » Tue Oct 21, 2014 4:59 pm
Engine bay wiring? Is that the actual engine harness or just the rest of the harness for the lights and what not?
davew7
Postby davew7 » Wed Oct 22, 2014 5:08 am
The harness is just for the engine[1985 MR-2], with engine plugs , injector, alt, sensors, and ECU plugs. Not for lites or chassis. Dave W
xxisukaxx
Postby xxisukaxx » Thu Mar 12, 2015 10:26 pm
Is the engine bay witing harness still for sale? If so, please let me know asap
davew7
Postby davew7 » Fri Mar 13, 2015 5:21 am
Yes
Still have the Big port engine bay harness. [MR-2}
Send me an E-mail with your Zip code and I can give you shipping $.
Dave W
laloarguijo
Postby laloarguijo » Fri Mar 13, 2015 9:32 pm
Just emailed you.. I need many parts
laloarguijo
Postby laloarguijo » Fri Mar 13, 2015 9:35 pm
Please contact me at lalo.arguijo@gmail.com i meed many parts
xxisukaxx
Postby xxisukaxx » Sat Mar 14, 2015 11:02 am
