Mostly Big Port 4AGE parts
Posted: Tue Oct 14, 2014 6:15 am
These parts left for AE86 & MR-2
4AGE Big Port Cam $12, pair for $20
GTS RWD engine mount [like new] $15
Cold start injector W/ HDW and fuel line $10
Oil pump W/inlet tube & Rear retainer Both W/ new seals $10
MR-2 Engine block Oil cooler adaptor $10
T-50 , 2nd motion Gear shafts [good for parts only] $10
T-50 stock shift lever with trans attach bracket $10
Emission vapor canister $5
O2 sensor W/ gasket and HDW $5
Other small MR-2 & EA86 parts, brackets, coolant in/outlets, Temp sensors for electrical and vacuum, and several relays. (Send needs)
Can supply photos on request
Will quote shipping from 48178, if you include your Zip code when contacting me at mtwhitt@sbcglobal.net
