Hi there,
I have a ae86 and recently bought a 4age 20v.
I'm thinking in getting a set of Tomei Poncam's.
My question is what other cams manufacturer do you recomend? I really want to keep VVT and mid range power.
Any help needed.
Thanks.
AE111 20v camshafts question
Re: AE111 20v camshafts question
The Tomei cams are the best I've run on the street. Smooth idle, great usable power across the rpm band rather than just peak power like most other cams.
- InitialB
Yeah if you want to keep VVT you should go poncam. Also heads up, you should have posted this in the tech section
Thanks for the help I thought the Pomcams are the better choice but wanna confirm it.
Sorru for the misplacement... Should i start the thead again on the tech section??
InitialB wrote:...Also heads up, you should have posted this in the tech section
- InitialB
Eventually a mod will notice and move it, but at least you got your answer
