I have 2 OER vvt controllers for sale.
They are used and in excellent condition. They both come with a plug and play harness, so there is no need to butcher your oem harness, just plug and go.
Located in Bronx NY.
VVTC & DA-111 units + PnP harness will cost $220 shipped (48 continental USA states only).
The OER variable valve timing controller (VTC) will allow the user to adjustment the opening range of the VVT at different RPM levels. This can results in better low RPM response (determined by setting). The device is fully functional, will work on a manual or automatic transmission 4age 20v (Blacktop) fitted car. The DA-111 allows the fine tuning across the RPM and does remove the stock speed cut. This also comes with the AE111 20V plug and play harness, so there is no need to butcher the oem harness to install.
Will ship international at buyers expense.
VVTC unit + PnP harness will cost $160 shipped (48 continental USA states only).
The OER variable valve timing controller (VTC) will allow the user to adjustment the opening range of the VVT at different RPM levels. This can results in better low RPM response (determined by setting). The device is fully functional, will work on a manual or automatic transmission 4age 20v (silvertop or blacktop) fitted car, it also come with the AE111 plug and play harness, so there is no need to butcher the oem harness to install.
