Ultimate Forged 4age high comp parts.
Posted: Thu Aug 04, 2016 5:56 pm
I am selling the parts to my built 4age. To maximize any build I would recommend buying the head and itbs as a unit as the head is ported for maximum air flow and has the elongated studs already installed for easy fitment with the ITBS. Similarly with the bottom end if you want the most strength and well oiled internals, the forged pistons and rods are a great combination with the 7rib block with oil squirters. I will also take offers on the build setup as a whole. Pictures are in the link below. Contact me at 520-449-5029 for any other information.
http://i1376.photobucket.com/albums/ah2 ... jk17bi.jpg
$Valve covers Sold
$Ported 4age big port head +Sold
comes with spring and caps.
$600 for forged rods and pistons high comp (needs one piston, extremely cheap for a bullet proof bottom end) +Shipping
The rods are Brian Crower with arp bolts
The pistons are Arias custom oversized domed pistons 81.5 mm bore 12:1 compression everything else is oem spec. Already has rings installed on the pistons.
$250 for 4age 7rib block with oil squirters +Shipping
comes with oil pan,rear main seal cover and oil pickup
Hks cams Sold
272 duration
8.35 lift
$50 arp head studs +Shipping
$550 for 20v silver top ITBS and billet aluminum 4age adapter (comes with hardware and gaskets direct bolt on) +Sold
HKS adjustable cam gears Sold
$200 4agze distributor (These are extremely rare) +Shipping
$20 Water pump +Shipping
$200 crankshaft +Shipping
I believe it is the 42mm crankshaft that fits in the 7rib blocks
$50 alternator +Shipping
$Valve covers Sold
Hks cams Sold
272 duration
8.35 lift
