Rare 4A-GE parts, cams, dry sump, intake Oregon
Posted: Sun Feb 24, 2019 10:02 pm
2020 bump and price drop. Updated with pics and more parts. Time to part with some of my treasures! I also have lots of used stock bluetop engine parts and some EFI/electrical parts in case anyone is looking. I will try to update the ad as stuff sells and as I unearth more from my stash.
Web 119 16-valve camshaft pair. Good used condition. 276 duration, 9.75mm lift. Big mid- and top-end N/A power. $OLD
Formula Atlantic dry sump pan. Beefy casting! Still has the Formula car mounts, could potentially serve for a crank sensor mount in an AE86, or easy to trim if needed. $OLD!
Modified reinforced oil pump housing for dry sump conversions, by Loyning's Engine Service. This no longer serves as an oil pump, but is needed to house the front main seal and the front sump mounting on a dry sump engine. Welded reinforcement at the typical weak spot for ultra high rpm use. $OLD!
Also available: Like new powdercoated bluetop valve covers. Red wrinkle finish with polished lettering. $OLD
Single AEM Tru-Time adjustable cam gear for 4A-GE. Pictured as black, actually silver in color, BNIB. $100 OBO.
Rare as hen's teeth original rubber elbow for the AE86 air intake! Long ago discontinued by Toyota #17881-16080 This goes between the AFM and the throttle body. In good used condition. $OLD
Open to package deals. Willing to ship. I've been moving on from AE86 stuff and into motorcycles, so not really looking for trades. Thanks!
