750cc Injectors, Fidanza Flywheel, Early Bigport 4age, 4agze
Posted: Wed Jun 05, 2013 6:31 am
by Spilly
Precision 750cc low impedance top feed injectors modified to work with stock 4age fuel rail. These require no further modification. Just install in fuel rail and bolt them up with the factory spacers. I ran these for less than 3k miles with MS2 (megasquirt ems). They work flawlessly. Uninstalled, put a few drops of oil in both ends and sealed them in a bag. I have injector opening times and other settings from msextra if needed. They were recently cleaned and flow tested by witch hunter before I purchased them. Purchased from a member on the other forum.
Sold! $150 OBO Plus shipping Sold!
More Pictures
Fidanza Flywheel 212mm
Picked this up from Jared on the other forum. The friction area, of the flywheel, was replaced and has not been used. I have a matching stock used disc and pressure plate you can have for free with this.
SOLD $170 OBO plus shipping SOLD
https://lh4.googleusercontent.com/-7FCoOF1IsNk/UaYwCbXZI1I/AAAAAAAAB-0/DWgq32dlOCk/w1008-h672-no/Fidanza+Flywheel.jpg
4age 3-rib Short block unassembled. This is the lightest, to my knowledge, production rotating assembly available for the 4age. The motor came out of a running car, got about 35 mpg, had 200k miles on it. I have everything organized and all of the bolts in labeled bags. I plastigauged and recorded the results of all the bearings while disassembling. They were all within the factory tolerances. I would recommend getting everything checked out by a machine shop. At a minimum replace all of the bearings and head bolts. Piston #3 has a tiny piece missing on the top outer face.
Sold! $75 OBO picked up Sold!
More Pictures Here
4age Bigport head off of the running motor from above. Comes with early bigport cams which have a little more lift. Completely stripped down except for valve guides. I have records of what shims came from what bucket and what the clearances were. The shims are in small labeled bags To my knowledge, the ports have not been touched. Needs valve seals at a minimum. The head, without the valve train, was cleaned via a spray wash cabinet and some light blasting with walnut shells. Comes with the blue valve covers. Cylinder Head 1 in the pictures.
Sold! $70 OBO Plus Shipping Sold!
More Pictures
4age Bigport head I used to practice some porting on. One of the chambers has the shrouding removed. I bumped into the exhaust port seats a few times on that chamber with a rotary tool, but I could only find scuff marks. Four of the valves have been shaved down. A few of the valves had a little rust near the seating section. The shims are still in the buckets they came from. After removing the valvetrain, the head was cleaned via a spray wash cabinet and some light blasting with walnut shells. Comes with the standard color valve covers. Cylinder Head 2 in the pictures.
Sold! $30 OBO plus shipping Sold!
More Pictures
Shortblock and both heads Sold! $100 OBO Picked Up Sold! Will through in whatever else you want/need that came off the motor. Freight for this is going to be around $150 so I would rather not ship.
Shortblock and Early Bigport Head Sold! $90 OBO Picked Up Sold!
4agze Knock Sensor $65 OBO shipped Cont US
Working Cruise control computer, and the two firewall mounted pieces. $45 OBO shipped Cont. US
Prothane Steering rack and front sway bar (18mm) bushings Brand new in box $20 shipped Cont US
If you see any other parts you want in the pictures let me know. I will be updating this post and thread with prices for the other pieces shortly.
All Pictures
Unfortunately I don't do paypal. I can do amazon payments (fastest way to do it), a USPS money order, or a Cashier's Check/Bank Check. Will drive a reasonable distance for the right deal.
I have had issues with paypal, to say the least, and scammers from ebay taking advantage of their automatic ruling system for claims.
It's pretty easy to setup an amazon payment account if you buy from amazon. My username is moldspectors@gmail.com . https://payments.amazon.com/sdui/sdui/index.htm
Re: 750cc Injectors, Fidanza Flywheel, Early Bigport 4age, 4
by Spilly
Pictures are old but they are from my previous posts on an MR2 board here http://www.mr2.com/forums/mk-1-parts-fs ... -more.html
Posted: Thu Jun 06, 2013 2:37 am
by gbogho
I would like the engine backing plate. Is that gmail address a good one to get ahold of you with?
Posted: Fri Jun 07, 2013 6:25 am
by Spilly
Yes, that is my primary email address.
Posted: Fri Jun 07, 2013 11:02 am
by ditn
pm sent
Posted: Fri Jun 07, 2013 11:23 am
by Spilly
Apparently I need more posts to PM ditn
Reply to your question:
I'm not sure ditn. Do you have a picture of your connector? I can compare and tell you if it's the same. I believe the connector is the primary difference in the knock sensors.
Posted: Tue Jun 11, 2013 10:55 pm
by mobilesuit818
I'll take the fidanza flywheel.
Email me at mobilesuit818@gmail.com
Posted: Wed Jun 12, 2013 1:23 pm
by ditn
missed your post
AE101 GTZ SENSOR, KNOCK CONTROL, 89615-12060
there is a difference between the map and afm ones they run on a different frenquency.
i will take a picture of my old broken one when i have a chance
Posted: Wed Jun 12, 2013 11:01 pm
by OooDangMark
flywheel still for sale?
Posted: Thu Jun 13, 2013 1:25 pm
by Spilly
The flywheel is sold pending funds.
Posted: Thu Jun 13, 2013 9:49 pm
by OooDangMark
damn..
Posted: Sat Jun 15, 2013 2:43 pm
by Spilly
Fidanza Flywheel Sold!!!!!!
Posted: Sat Jun 15, 2013 6:42 pm
by Spilly
Prices dropped!
Posted: Tue Jun 18, 2013 4:43 pm
by Jayce_ae71
How much would you want for the block crank, early bigport bare head and valve covers? Shipping cost to 64119
Posted: Wed Jun 19, 2013 8:09 am
by Spilly
Freight is going to be around $150. If you're still interested I can get you a more accurate quote.
Posted: Thu Jun 20, 2013 3:25 pm
by Jayce_ae71
Definitely interested, it will be next weekend before I can do it but I'll grab it from you for sure
Posted: Fri Jun 21, 2013 8:44 am
by Spilly
Shortblock and two heads sold pending funds.
Sorry Jayce_ae71, a guy from the MR2 forums beat you to it.
Posted: Fri Jun 28, 2013 6:56 am
by Spilly
Mods please close. Major parts have been sold.
