Contact info:
Christopher
nerzoid@gmail.com (also used for paypal)
call/text - 602-nine eight nine - 0595
Any Shipping will be from 85029
I tried to be as detailed as I could about the items but feel free to ask questions or request pictures. Open to offers/trades.
20v Silvertop parts:
20v Head (cams, journals, head): $150
Gam Gears (VVTI intake/exhaust): $60
VVTI Sensor: $60
Water Ports (uncut): $15/each
Water Pump (Toyota, Used, very clean and no slop/play/non leaking) : $25
Water Pump Backing: $30
Knock Sensor: $60
Timing Belt Cover (mid section): $25
Timing Belt Cover Backing on Intake Side (metal piece that bolts on head): $25
4AGE Parts:
Oil Cooler Setup (sandwich plate, cooler, return line fitting for pan) - $75
4AGE Valve Covers - $30
4AGE Bluetop cam Gears - $30
4AGE Bluetop ECU - $40
4AGE Oil Dip Stick - $20
4AGE Intake Manifold - $35
4AGE Throttlebody - $35
4AGE T-vis Butterfly Plate - $35
Power Steering Pump (worked before taken off, been sitting for a while so ) - $30
AC Compressor (worked when taken out of vehicle 3 years ago, been sitting since. Acceptable amount of play in pulley and ports have closed while in storage, but it's not been tested recently) - $40
Other AE86 parts:
GT-S Shifter (no boot, bushing or knob) - $30
Stock Steelies (no tire) - $10/each
Blue Door Handle Cups - $20
Dash coin holder insert - $15
Rear Seatbelts - $20
Trunk/Gas door lever - $5
Gas Door (hinges included) - $30
Left Headlight Skin - $20
GE headlight bulbs - $3/each
Uncracked kouki tail light (Left) - $50
Cracked kouki tail light (Right) - $25
Zenki Lisc. Plate light - $10
Front Bumper - $50
SR-5 Front Bumper Plastic set (kouki) - $40
SR-5 Front Bumper (kouki) - $50 with support/ $25 for just plastic
Passenger side Door (some minor damage) - $40
Toyota Oil Cap - $7
SR-5 Driveshaft (Comes with a good carrier bearing. U-joints show signs of wear, but it functions fine) - $50
Driveshaft Carrier Bearing Heat Shield - $25
Brake Master Cylinder (w resivior, worked before removed) - $20
- AC:
o vents - $4/each
o Defrost Vent - $15
o Ducting (to back seats, under front seats) - $5/each
o Ducting (under dash, small pieces) - $4/each
o Ducting (under dash, big pieces) - $5/each
o Controls: $20
o Hard lines: $15 each
o Heater core housing: $25
o Blower: $25
- Power Steering:
o Column: $45
o Lock cylinder housing: $25
o Lines: $10 each
o Rack: $35 (comes with functional tie rods)
o Reservoir Tank: $20
o Bracket and Tensioner pulley/adjustment screw: $35
MISC Car parts: (pics below)
Nissan 240SX 4x113.4 Stealies (2) - $15/each
Nissan 240SX 4x113.4 Stock Rims (2) - $25/each
Aisin Electric Fan - $4
Greddy Type RS - Blowoff Valve - $50
92 Camaro/Trans AM/Firebird wing - $20
