Hello,
I have loads of brandnew oem 4AGE 16V or 20V or 4AGZE engine parts (no used parts).
Email me with a part number and i'll give you a price.
Take in mind in live in holland, so insured shipping (Worldwide) till about 2 kg's will cost around $35
New and OEM 4AGE / 4AGZE 16v and 20v parts
Re: New and OEM 4AGE / 4AGZE 16v and 20v parts
UP!
Listing parts will definetly help ur sale cause we don't know what u have.
Thanks and have a nice day
I have pistons, rings, bearings, headgaskets, oil pumps, water pumps (OEM and GMB), ignition wires (OEM and other brand). You name it, i most probably have it
- Rogue-AE95
Do you have any of those 10.1:1 Euro spec TVIS pistons? 18mm wrist pin? (Not to be confused with the 10.3:1 smallport pistons.)
http://forums.club4ag.com/zerothread?id=107132
Do you happen to know what part number the piston should be?
- Rogue-AE95
I'm not sure if this is the right one for an 18mm wrist pin, but the part number for the .5mm oversized set is:
13103-16030
http://forums.club4ag.com/zerothread?id=7282
Don't know if the rings are the same as USDM bigport or not. Part numbers are different but who knows...
13103-16030
I can get the pistons with number 13103-16030. Only a few are available and they cost $335 ex shipping.
With the rings with number 13013‑16180 it'll cost $485
I don't have a part number, but I have a part diagram that I circled the part I need on. I need the throttle link bracket and the link rod for a 20v Blacktop circled in the picture.
http://imgur.com/mAj6XGG
Checked toyodiy over and over again and can't find the part numbers either. I need them to check if i can order them.
Don't happen to have a 16v crank pulley do you?
Cam cover gasket?
Dizzy Cap & Rotor?
Cam cover gasket?
Dizzy Cap & Rotor?
Can order all. I think i might even have a 16v crank pulley.
If you need the parts please send me a pm
do you have 20v silvertop fuel injectors?
I have 2 sets of blacktop injectors. Don't know the condition while i bought them as a spare and never used them. Will sell for €35 a set plus whatever shipping will cost.
