FS: Silvertop 20V cams 284 duration, 8.5mm lift $500
Gabriel Tyler
Postby Gabriel Tyler » Mon Sep 30, 2013 12:05 pm
This was the set of cams we used in our Formula D car back in the day.
TED Components Kamikaze Cams for the Silvertop 20V, 284 duration on intake and exhaust, 8.5mm lift. This is the largest setup I believe you can use with the factory valve springs.
Comes with the complete set of buckets and shims, numbered and labeled to make them a direct drop in for the 20V.
Our stock 20V saw 134 RWHP running on a standalone. With no changes other than these cams we saw 154 RWHP running on a standalone. We then ran a wet fogger nitrous setup whenever the motor was above 4000RPM and 7/8 throttle. On the juice we saw 210 RWHP.
Complete pair of cams with shims an buckets is $500
Hit me up at ggtyler@yahoo.com or 530-672-8600 if you are interested.
Allstar twenTycharged
Re: FS: Silvertop 20V cams 284 duration, 8.5mm lift $500
Postby Allstar twenTycharged » Wed Jan 01, 2014 1:51 pm
You have got email.
