4AGE Turbo Conversion Package: MS, LC-1, T28
Devil Frog
Postby Devil Frog » Tue Dec 24, 2013 9:50 am
I am no long have my 1987 MR2, and have some parts for a turbo conversion that I never completed
Up for sale as a package:
-1 Assembled 4age Megasquirt DIY PNP. comes with GM AIT sensor, USB adapter and cable - http://www.diyautotune.com/catalog/diypnp-c-75.html keep in mind the assembled version of this goes for $800 alone http://www.diyautotune.com/catalog/megasquirtpnp-g2-t8590-for-the-8589-toyota-4age-and-22re-p-503.html
-1 LC-1 wideband with Bosch sensor and bung
-1 disassembled (all parts bagged and labeled) genuine Garrett T28, from Nissan Skyline GTR. The trubine blades were broke, and it had massive shaft play, but I am including a new turbine wheel (needs to be balanced with compressor wheel) and new turbo rebuild kit
I built the MS, and ran it in NA on my MR2 for about 500 miles, it will require tuning to your setup but otherwise is PNP. Here is a you tube link of it starting up http://www.youtube.com/watch?v=pfBTrHaUojs
The LC-1 is setup to run power and ground off the MS and deliver 02 signal through aux connector, and the calibrate button and light are mounted in the MS case for convenience. So this really is plug n play aside from having your exhaust shop weld in the wide band bung (included). I am including a GM IAT sensor, which is optional if you want to delete the restrictive factory AFM sensor.
I am asking $900 + shipping obo. PayPal only.
I am not a regular user of this forum, so email me at isaachbrito@gmail.com if you are interested.
