Complete 4A-GE Redtop Largeport w/ JDM MAP setup
Posted: Fri Dec 27, 2013 10:42 am
by souldrift86
Seasons Greetings Club4ag,
I’m selling my 4A-GE Redtop Largeport w/ JDM MAP setup. The motor was rebuilt back in 2008. It had limited use throughout the years that followed due to being overseas.
I would like to sell the entire drop-in-and-go swap. Minus the radiator since I still need it. If there isn’t much interest than I will part out everything. This would be a decent candidate for a carb setup. Sometimes sacrifices need to be made to get other projects completed.
Regarding potential buyers near Yuma, AZ, I’m willing to make a trip to SoCal or Phoenix to get this to a new home. All I ask is for the buyer to pay gas both ways. ;)
JDM 4A-GE redtop largeport engine: SOLD
• Second-generation (87.5-89.5) 4A-GE 16v redtop largeport.
• Rebuilt head (1000 miles ago) by Tech2 Motorsports. Have documentation.
• New gasket kit - Paid $185.
• Head work was $450 with additional $450 for removal/install of cylinder head.
• Originally came from a JDM AW11 MR2.
• Stronger crank and larger diameter bearings for connecting-rod big ends (42mm crank x 20mm wrist pins) as compared to the first-generation bluetop largeport.
• 7-rib block (no oil return or squirters).
• T-VIS maintained.
• 190 psi across all cylinders.
JDM MAP setup:SOLD
• JDM MAP ECU
• JDM distributor
• JDM coil & igniter
• JDM MAP sensor
• Air temp sensor
• Cold start injector
• Dash harness for MAP setup.
• Throttle body w/ TPS and IACV. TPS works but couldn’t get a perfect reading from it. Here’s the part # 89452-28010. $20.00 on ebay.
• AE86 RWD water outlet w/ coolant temp sensors. Water temp sensor to ECU should be replaced, but included. Here’s the part # 7999-01080775I. Cost $36.04 new.
• JDM AE86 MAP engine harness to work with dash harness. Wired by Tech2 Motorsports. Paid $150 for the actual JDM MAP harness. Paid $150 for custom wiring to dash harness.
Parts included:
• Short ram air intake w/ AEM dry-flow filter.
• OEM flywheel SOLD
• Clutch and pressure plate SOLD
• Stock fuel rail
• 250cc, green, 13.8ohm, #23250-16110 injectors. No resistor pack required.
• Alternator
• Starter SOLD
• T50 transmission (no grinds at all). SOLD
• T3 short shift kit installed on T50.
• Water pump SOLD
• Stock pulleys SOLD
• Oil filter new and on block.
• GT-S oil cooler w/ hoses SOLD
• Water hoses to radiator
• Stock exhaust manifold w/ heat shields.
• Redtop largeport intake manifold w/ TVIS. Has IAT sensor hole.
• Valve covers – Metallic red. Shaved letters. SOLD
• Quick release oil drain plug. SOLD
• Slave cylinder. SOLD
• Engine mounts and brackets.
• TRD plug wires.
• Fuel filter w/ hose.
• Heavy gauge grounding strap for engine.
• Straight exhaust with added resonator.
• Stock cat gutted.
• Electric fan.
• Autolite spark plugs. SOLD
Excluded:
• Koyo radiator. Need this for my BT20V.
Video of the motor running:
http://vimeo.com/81359160
Pics of everything included in the bundle: SOLD
JDM ECU: SOLD
Part #: 89661-12050 175700-0031 AE86 5.83-5.87 JAP
JDM distributor SOLD
JDM coil and MAP Igniter SOLD
JDM MAP sensor SOLD
Engine harness for JDM MAP ECU. SOLD
Dash harness to work with JDM MAP setup. SOLD
Air intake w/ AEM dry flow filter.
TRD plug wires
4age starter SOLD
T50 transmission SOLD w/ T3 short shifter (Still for sale)
Stock GT-S oil cooler SOLD
4A-GE stock exhaust manifold w/ heat shields
Fuel filter w/ hose (used once for 10 mins). Like new.
OEM catalytic converter (gutted)
JASMA style exhaust? Cut tip to fit under JDM zenki bumper. Not as loud as my Trust DD but still loud. My best comparison...
Water hoses
Electric fan. This wasn't what I used for this motor but will work. Just needs wiring and relay. The other fan is staying with the Koyo radiator it's attached to...
Autolite spark plugs - New from 50 miles ago. SOLD
I have every receipt, documentation, oil/transmission fluid change, service work and everything else regarding this motor with dates. I can make copies from my record book for those interested. Thanks!
$1800 OBO
Located: Yuma, AZ
Text: 530949seven2three0
USPS shipping and full paypal fee 3%.
Re: Complete 4A-GE Redtop Largeport w/ JDM setup
Posted: Fri Dec 27, 2013 4:43 pm
by Musink
Dude Thats A Killer Deal! I Will See What I Can Pull Together To Get this From You!!!
Posted: Fri Dec 27, 2013 6:14 pm
by souldrift86
Musink wrote:Dude Thats A Killer Deal! I Will See What I Can Pull Together To Get this From You!!!
Okay... keep me posted :)
Posted: Sun Dec 29, 2013 11:02 am
by souldrift86
Sunday bump...
Re: Complete 4A-GE Redtop Largeport w/ JDM MAP setup
Posted: Tue Dec 31, 2013 10:33 am
by souldrift86
Getting decent offers and requests. Bump...
Posted: Sun Jan 05, 2014 9:28 am
by souldrift86
Engine and Transmission SOLD...
Parts will have prices soon.
Posted: Wed Jan 08, 2014 1:26 am
by ronny
did the wiring sell with it?
im interested in the whole map setup. thanks
ROn
Posted: Wed Jan 08, 2014 10:06 pm
by souldrift86
ronny wrote:did the wiring sell with it?
ROn
Still have it. I sent you a PM.
Posted: Sat Jan 11, 2014 6:05 pm
by ronny
sent you back PM - any update on it?
thanks!
ROn
Posted: Sat Jan 11, 2014 8:35 pm
by souldrift86
ronny wrote:sent you back PM - any update on it?
thanks!
ROn
Sorry! Sent PM days ago but it somehow didn't get sent. PM'd again...
Posted: Sun Jan 12, 2014 6:42 pm
by Spoold86
Interested in oil cooler plz pm
Posted: Mon Jan 13, 2014 3:07 pm
by souldrift86
Spoold86 wrote:Interested in oil cooler plz pm
PM sent.
Posted: Tue Jan 21, 2014 8:43 pm
by souldrift86
Hey man can you PM your address? For some reason every PM I send just stays in the outbox...
Posted: Wed Dec 31, 2014 7:25 pm
by BryanHernandez117
Any of this still for sale?
Posted: Thu Jan 01, 2015 9:46 am
by souldrift86
Yes. PM me for what you need.
Posted: Mon Jan 05, 2015 4:29 pm
Have the fronts covers any of the three?
Posted: Mon Jan 05, 2015 6:10 pm
by souldrift86
If you're talking about the cam gear cover and covers for the timing belt I don't have them anymore I let them go with the engine when it sold. Sorry.
