***Illegal Garage Parts***
Illegal_Garage
January 2013
Still building parts for the AE86 GT-S
1 Piece light weight drive shaft
13 lbs 10 oz
over 7 lbs lighter than stock!!!
$355 plus shipping ($400 shipped in the USA)
Flex pipe to Delete Cat Converter
$72 shipped
4AGE Clutches
*200 mm Custom hand build disk in San Jose, Ca
$335 and up
*212 mm Custom hand build disk in San Jose, Ca
$350 and up
*224 mm Custom hand build disk in San Jose, Ca
$375 and up
Can Also make clutches with W series spline
All clutches are made to order (takes 5~10 working days)
$375 and up
Light weight flywheels also available such as Generic, Toda, Race Gear
$200 and up
LSD bearing Kit $150
2 pinion bearings
2 Diff bearings
OEM Toyota Pinion Seal
OEM Toyota Crush Sleeve
OEM Toyota Pinion Nut
Brake Pads Sets
Carbon Metallic (high dust)
$50 Fronts
$50 Rears
Brake Rotors Blank
Made in the USA
$25 Fronts
$25 Rears
Uncle Bob Brand Steering wheels $129
350 mm Diameter
Suede or Perforated leather
Deep Cone or Traditional
Also able to Order and Ship most OEM Toyota Parts
e-mail me if you have any questions
Thanks
Max
Maxfrommisawa@aol.com
13 lbs 10 oz
$72 shipped
4AGE Clutches
$335 and up
$350 and up
$375 and up
$375 and up
$200 and up
2 pinion bearings
2 Diff bearings
Brake Pads Sets
$50 Fronts
$50 Rears
Brake Rotors Blank
Made in the USA
$25 Fronts
$25 Rears
350 mm Diameter
Thanks
Max
Last edited by Illegal_Garage on Sat Feb 02, 2013 5:22 pm, edited 2 times in total.
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
Re: ***Illegal Garage Parts***
great your back!
So i measured and measured and now im 100% its 230mm.(surface area clutch) (its an ae101)
its this correct then?
I would need a clutch kit for a w58.
Illegal_Garage
AE101 GZE?
Max
Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
check your email.
Illegal_Garage wrote:AE101 GZE?
Max
yes its a ae101 gze the last version of the gze
Illegal_Garage
what transmission are you going to use?
I am not sure if it will fit in a W series bellhousing
also i need a pic of your flywheel
there was a few diffrent ones for GZE
Max
Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
W58
http://i48.tinypic.com/2w22zhh.jpg
I have a niteparts bellhousing and it hits the belhousing but i was gonna grind the inside until it rotates
Or will the clutch also hit the bellhousing?
I will get a picture of the flywheel as soon as the snow melts,impossible right now since the car isnt at home
Illegal_Garage
the clutch protrudes quite a bit
I dont know if you are able to grind off that much material
230mm clutch might be over kill
I have seen a turboed 4AGE in Takahiro's (green Levin built by Blacktrax) car making 293hp and he ran a 200mm clutch with no problems
Max
Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
Illegal_Garage wrote:the clutch protrudes quite a bit
Max
yes thats my cocern also.
If i would use another set however i would like the 225 mm gze flywheel&kit.(i no longer have 200mm flywheel so i will need to buy one then)
those seem very common.
that should fit the niteparts bellhousing+w58 right?
do you still have resurfaced flywheels?
Illegal_Garage
I don't have any more good used flywheels
I would have to sell you a new one
Max
Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
Illegal_Garage wrote:I don't have any more good used flywheels
Max
how much does an oem new 225mm flywheel cost?
best regards
Illegal_Garage
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
looks good,are those holes in the back normal?
Illegal_Garage
I dunno should contact the seller on eBay
Max
Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
waiting for an answer,
can you pm me a price for the clutch kit for w58 225mm flywheel?
Zach90Turbo
ditn wrote:looks good,are those holes in the back normal?
Yes, those holes are normal, it's where they removed material to balance the flywheel.
Illegal_Garage
Ditn I am not the one selling the flywheel.
Also when dealing with a GZE you would have to ship me your flywheel
as some of the GZE flywheels have an odd mounting configuration
This is to insure you get the correct pressure plate
Max
Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
Illegal_Garage wrote:Ditn I am not the one selling the flywheel.
Max
Since i live in belgium i think it would be best(if you can&its a good flywheel) if you would buy the flywheel and add it to the clutch kit
Else i have to buy the flywheel get it shipped to belgium and then back to the usa with double douane charges.
Illegal_Garage
Send me an e-mail and I will see what I can do for you
Max
Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
can you do clutches/flywheels for Beams 3sge?
i'd be very interested in buying a good clutch/flywheel combo. Otherwise I'm going to blow my life savings on an os giken..
Illegal_Garage
Yea I have done a BEAMS before
Max
Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
emailing you now.
i have sent you an email.
drove up to SJ and bought a driveshaft 2 nights ago, installed it last night
it was very professionally packaged, quality looks great. drove it on the freeway, no problems so far
car feels quicker/more responsive. best part is the joints are serviceable
Illegal_Garage
Thanks for the positive feedback Bing
Max
Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
wrong email so resent mail
Illegal_Garage
OK got it and working on your request.
Max
Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
Illegal_Garage
To the top
Thanks
Max
Thanks
Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
- death_blossom
Max, a friend of mine said you used to sell Illegal Garage brand flywheels? he has one and is very happy with it. do you still sell these?
Illegal_Garage
e-mail me for more info about the flywheels
Max
Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
