Engine Build Goodies for your 4AGE
Z1 Performance
Postby Z1 Performance » Mon Sep 29, 2014 2:21 pm
HKS 4AGE 16v Kevlar reinforced heavy duty timing belt + HKS adjustable cam gears (Pair): $535 shipped in the lower 48 states
HKS Metal Headgasket for 4AGE 16v - 82mm, 1.6mm thick - 9:1 compression with standard pistons
82mm, 2.0mm thick, 8.7:1 compression with standard pistons
Your choice, $144 shipped in the lower 48 states
HKS Valvespring set for 4AGE 16v: $160 shipped in the lower 48 states. Suitable for cams with lift up to 8.5mm and 60 lb seat pressure, making them a great option for an engine that needs to last and not be torn down often. We can package these with HKS cams as well
HKS exhausts are offered in both Sport and HiPower configurations - contact for pricing
ARP Engine Build Combo: 16 valve or 20 valve (specify when ordering)- Includes New ARP Headstuds, Main Studs and Flywheel Bolts: $269 shipped in the lower 48 states. Can also add in rod bolts for those who need it as well
Last edited by Z1 Performance on Fri Oct 10, 2014 7:10 am, edited 1 time in total.
Re: Engine Build Goodies for your 4AGE
Postby oldeskewltoy » Tue Sep 30, 2014 8:38 am
Z1 Performance wrote:HKS Valvespring set for 4AGE 16v: $160 shipped in the lower 48 states. Suitable for cams with lift up to 8.5mm and 60 lb seat pressure, making them a great option for an engine that needs to last and not be torn down often. We can package these with HKS cams as well
Are the HKS springs 2201-RT004?
http://www.mr2oc.com/showpost.php?p=510 ... stcount=22
from link above wrote:I asked HKS about their spring 2201-RT004 some time ago and got this response:
The basic specs are:
Set height: installed length: 34.70mm installed load: 12.00 kgf
Full lift: length: 26.60mm load: 44 kgf
Converted for easier understanding - Seat pressure @ 27#s, max lift 8.1mm (valve lift), pressure @ full lift 97#s
Z1 Performance
Postby Z1 Performance » Sun Oct 26, 2014 12:24 pm
ttt
the specs I have came from HKS too - so I have asked again and am waiting on another confirmation
