It's a Boost Controller, It's a Wideband, It's a Datalogger!
Posted: Fri Aug 08, 2014 2:53 pm
by Z1 Performance
If you have a turbo charged car, the 2 most important gauges you can install are a boost gauge and a wideband air fuel ratio gauge. In the past, this generally meant individual gauges stacked up on your a pillar, or on top of the dash. Let’s face it, that look went out even before the original Fast and Furious movie.
Innovate Motorsports came up with this thoughtful, intelligent solution. An all in one gauge that combines a powerful electronic boost controller with a wideband air fuel meter. It even includes an integrated shift light! Housed in a convenient 52mm (2 1/16″) body. The boost controller portion will control up to 44 psi (4 bar map), has programmable waste gate reference pressure threshold, has programmable solenoid duty cycle (with separate gain control function), and the best part, a user-programmable boost cut safety using Air/Fuel and Pressure as as data reference points!
The wideband portion is compatible with ALL fuel types, gives you the bility to calibrate O² sensor for maximum accuracy
has one configurable linear 0-5v analog output and gives you 4 channels of log-able data (MAP, RPM, A/F, WG duty)
We are offering Free Shipping to ALL 50 states on this through 8/15/2014!!
