One big item on the list is the piece I need to get cut for the AW11 coolant fill neck.
Once I get that cut I am all go to start producing these.
It's always hard to say what the final price is going to be but for the first run I am happy to aim on the low side just to get a run out and get an idea what it will take to produce them. This means the price could go up after the first batch.
I will cap the price right now at $180. If we can get over 5 I will cut that to $160.
If you are interested in an aluminum coolant fill neck now's the time to jump on it.
These will be made with a mishimoto coolant fill neck and should be compatible with OEM caps and Mishimoto and other aftermarket caps.
The basic design doesn't include the hose holder that the stock one does. For the first run at least this will add $40 to the cost if you want it added.
Other than that it will be identical in dimensions and design to OEM.
Another item on the drawing board is a spacer for MK1noobs setup. He is currently using his TVIS plate to space out my 4 runner mani to clear the supercharger which is less than ideal. I am going to look into making him a plastic spacer plate that isn't split like the TVIS plate. This opens up a bunch of possibilities. If anyone wants to eliminate their TVIS this would work for that. If anyone wanted a thinner version to act as a thermal insulator we could do that as well.
If anyone is interested in anything like that then let me know.
As always I can also get flanges for intake manifolds for all gen 4AGE, supercharger flanges, throttle body flanges and more. If it's anything common that I don't have on file I'll draw it up for free. If it's not common my CAD rates are very cheap because it's one of my favorite parts of my job.
I have had some requests for stainless header flanges or other designs that SV3power doesn't offer so I have drawn up an exhaust flange.
If you want a basic mild steel 3/8" flange that works with 16v and 20v I won't beat SV3powers price and quality.
If you want a flange out of stainless or thicker material or a flange that doesn't have both sets of holes or something like that then let me know.
I will also have flanges available for the 16 valve and 20v header to downpipe.
I am in the process of fabricating my first customer oil pan. I ended up changing the design a little to help funnel oil from the pressure bypass to the sump. This will greatly improve keeping the sump full on hard right handers.
This does mean I will need to modify my design before the next order but the changes will be pretty small.
If you want an oversized oil pan now would be the time to get your order in.
If you need anything else waterjet, CNC'ed or anything like that now would be a good time to hit me up.
I hope to get an order in within the next two weeks. If something comes up that is more urgent I can always push it through as a single order but at a slightly higher cost.
