WTS 1981 toyota starlet. 3000 obo
Not interested in too many trade, but lemme know what you have.
I have put a LOT of work into this car.
It still needs a few things to make it run.
Mods
rx7 FB GSL-SE rear end. with mazdatrix clutch packs that makes it basically into a two way. custom built by chambo. por-15 coated
Front end converted to AE86 suspension.
paradise racing coilovers up front on AGX's
AE86 tie rod ends which will give it more angle and toe adjustment, brand new.
mr2 AGX out back with AE86 megan lowering springs. the rear had a few dead coils cut out so the car sit at a good level height.
FULLY custom rear adjustable 4 link.
Centerline wheels, 14x6+0 i beleive Tires are dead but i have good tires i can mount up.
SUPER rare kamei lip, probally the only one in the states.
Rear hatch spoiler
4age with t50 almost full swap.
I have the mounts from t3 already, all it needs is a wiring harness really. and a driveshaft +exhaust made.
decent greddy clutch
Wilwood hydrolic clutch pedal these things came with cable clutches. the wilwood set up makes it super easy to convert
MSD 6A and msd blaster coil
Old fiat steering wheel with works bell knock off hub
rx-7 seats, uninstalled, they just need some brackets fabbed up
ZG fender flares
will also come with 2x ae86 and starlet strut casings you can send these into t3 and gabe will give you $350 credit, they have a TON of stuff for starlets now.
I put about 6k into this car not including the cost i bought the car for.
