1989 Nissan Skyline GTS-T R32 Sedan 4 door!
Elvin Wes
Postby Elvin Wes » Wed Dec 03, 2014 12:19 am
Located in Long Beach California 90805
Come take a look at it in person!
(323)645 O229
100% Legally imported on behalf of the 25 year law NHTSA Exemption rule.
4 Door Sedan
RB20DET
5 Speed Manual transmission
215KM on the clock
Power windows
Power steering
Heater works
A/C needs to be looked at to blow cold again.
was previously an automatic car until they swapped it to 5 speed, runs and drives great.
Repainted pink pearl
Advan wheels
Coil over suspension
Strut bar
Turbo timer
Boost gauge
Aftermarket steering wheel
DVD Navigation unit
CD/RADIO/USB/MP3
No oil leaks, no grinds on transmission, clutch feels great, no complaints.
Put gas and go!
Here are the forms I will provide you with,
http://www.importavehicle.com/1.aspx
The Bad :
Needs Sunroof switch, yes it works with the little jumper wire. Temporary until you locate a switch.
Missing sunroof panel, interior panel that is, I don't mind the sun hitting me in the face every now and then.
Ebrake light comes on and off, i'll check it tomorrow, it's works by contact so should be fixable in just a few minutes. Bad ground or something.
Clouds
Re: 1989 Nissan Skyline GTS-T R32 Sedan 4 door!
Postby Clouds » Wed Dec 03, 2014 5:12 am
It's sooooooo cleeeeeeeean. :o
TheBigCU
Postby TheBigCU » Sat Dec 06, 2014 11:29 am
Would be an awesome Daily!
Elvin Wes
Postby Elvin Wes » Fri Dec 26, 2014 12:28 am
Sure is!
