5 speed
173k miles
619-971-6726 Text preferred
$15,500 OBO
Suspension
Tokico white adjustable struts
Full energy suspension bushing set
Skunk2 camber kits
Custom traction bar on heim joints
Interior
Very good condition with no excessive wear rips or fades
Pioneer headunit
Tunerview mounted under radio
skunk2 shift knob
Dynamat in truck as well as Mercedes S class sound deadening material
10 gallon fuel cell with in tank walbro 255LPH fills in stock location and vents outside
AEM methanol kit
Engine
Darton 85mm sleeved block
CP 85mm 9:1 pistons
OEM Honda brown bearings
micropolished and balanced crank
Eagle H beam rods
Full ARP hardware
Black has been line bored, honed, and ready for assembly
full rotating assembly balanced by Arce enterprises
85mm Golden Eagle headgasket
ported ITR head
ITR cams
skunk2 valve springs
skunk2 retainers
supertech valve guides
Head was decked hot tanked and assembled by Arce enterprises
Skunk2 intake manifold
Skunk2 throttle body
Moroso oil pan
OEM Honda oil and water pumps
Skunk2 cam gears
All ignition parts replaced with OEM Honda
Hondata S300
AEM fuel rail
AEM FPR
RC750 injectors
Turbo
Stainless steel top mount manifold
Precision 6031 turbo
Tial 38mm wastegate
Greddy BOV
Backdoor intercooler
Polished IC piping
3 layer silicone boots and T bolt clamps
3 inch ceramic coated downpipe
3 inch aluminum exhaust all mandrel bent
Magnaflow muffler
Transmission
CRV 5 speed syncrotech built
LS 5th gear
Syncrotech carbon syncros
1st and 2nd face plated
One off Mfactory LSD
Stage 4 competition clutch set
DSS 3.9 axles larger hubs
ARP wheel studs
AWD (DO NOT MESSAGE ME ASKING AWD QUESTOINS)
CRV transfer case
Suzuki samurai driveshafts custom made
DSM u joints
custom adapter flanges
ARB air locker
custom carrier bearing
CRV rear diff
custom CRV/civic rear trailing arms
Rolling
Fresh polished si wheels
Brand new 205-50-15 Dunlop durezza Z2
Motor is brand new all parts were purchased new nothing used and only used best of the best all gaskets seals and hardware are all oem purchased from dealer. On a 1.8L non sleeved block the car produced 488AWHP tuned by Daniel at church automotive the new motor will be well over 550whp I will be tuning as soon as it's broken in.... Car is a daily driver with working ac and heater and is a total sleeper, stock driving feel until you lay into the throttle. I have driven the car multiple times from SD to LA/OC with zero issues and wouldn't hesitate to drive it anywhere worry free. I would entertain trades just please only let them be of same value and quality...... Mainly looking for 03-04 Mercedes Benz E55 any color except black.. Please send cash or trade offers to 619-971-6726
<font color=""Red"">
this is not a stain on the carpet, that light spot must be the sun...</font>
=draggbody;49523149]
[/QUOTE][quote=draggbody;49524470]
[/quote]
