FS: 1985 Corolla GTS (San Mateo, CA)
Posted: Fri Jun 20, 2014 11:20 pm
PLEASE USE EBAY TO CONTACT ME. Thanks.
1985 Toyota Corolla GTS (AE86) with a CLEAN TITLE. It has only been daily driven with regular maintenance. It has been sitting for about a year, but still starts up right away and runs strong. It should pass smog with an appropriate warmup, however, I would recommend a tuneup with a new timing belt as it has never been changed since I have owned the car. The frame is straight and the body has no rust. The previous owner did repaint the car, which has since faded. There is no noticeable overspray.
This model does NOT have a sunroof or AC.
Additions:
Illegal Garage Clutch
Kaaz 2-way LSD
Slotted rotors
Steel brake/clutch lines
14" Konig Rewind Wheels with Kuhmo Solus KH16 tires (85% tread)
Suspension recently aligned
Issues:
The temperature lever for the climate control is jammed, i.e. no heat.
Ripped upholstery
Transmission fluid spilled on backseat carpet (smells a little funky)
Ebay listing: http://www.ebay.com/itm/171363946951?fo ... &viewitem=
Additions:
Kaaz 2-way LSD
Slotted rotors
Issues:
Ripped upholstery
