I'm selling my beloved Hachiroku. The building of this car took 4 years and ended about 3 years ago. The body has been sandblasted, repaired and strengthened (custom built FIA certified cage) and even today is almost rust free. The fuel and brake lines were rerouted inside the cabin using braided lines, according to homologation regulations. The engine was built for reliability and the chassis for handling. With all this said and done the rear brake calipers needs some overhaulin’ and the baulk ring on the 3rd gear needs replacement.
In the last two years I didn’t have the time or the money to drive the car, let alone working on it… …so I’m selling it. I hope this is for the good of the car.
Engine:
CatCams (7105137) camshafts
TODA valve springs
Adjustable aluminum cam gears
Mildly ported and polished cylinder head
Port matched intake and exhaust manifold
New OEM water pump
New high capacity OEM oil pump (with HKS OilUp Kit)
KSD Engineering IACV block-off plate
Huge aluminum radiator with electronic cooling fan
Oversized aluminum oil cooler
MOCAL HiFlow thermostatic sandwich plate
The starter and the generator has been reconditioned
Markus Martelius R1 header (4-2-1)
Custom made 55mm exhaust system
Cusco oil catch can
Kevlar reinforced NGK silicone ignition coil plugs
TOMEI fuel pressure regulator
Drivetrain:
Techno Toy Tuning - shifter and short shift kit
KAAZ 2-way diff and a totally reconditioned rear axle
New OEM master and slave clutch cylinders
Kevlar reinforced clutch
Lightened flywheel by Havassy
Lightened and trued v-belt pulley
Cusco engine and transmission mounts
Running gear:
Largus anti-sway bars front and rear
Whiteline adjustable panhard rod
Cusco Type OS front strut tower bar
Prothane urethane bushings all around
Suspension for the summer season:
Tokico HTS102 short stroke dampers front and rear
TRD 6kg/mm springs in the rear
Ground Control Coilover Kit up front (with Eibach ERS 8kg/mm springs)
Techno Toy Tuning NRCA adapter
Techno Toy Tuning adjustable pillow ball camber plate
Techno Toy Tuning “upper hat” system (top spring plate with bearing for smooth steering)
Suspension for the winter season:
Front: “thick shaft” Bilsteins
Rear: adjustable Koni yellows
20 mm aluminum wheel spacers for the front and rear
Toyota Yaris electric power steering
Quaife Quick Steering Rack
Short OEM steering knuckles (from the PS version)
Reconditioned front master cylinder
Drilled and slotted brake rotors front and rear
Hydraulic ebrake (with 0.625" Girling cylinder)
Goodrich flexible brake lines all around
Chassis:
Sandblasted and full Teroson underbody coating and body cavity protective treatment
FIA certified cage (“Grámán” branded)
New OEM headlights with 55W-os (4300k) biXenon kit
"RedLine" JDM tail lights (complete rear end)
Fiberglass bonnet
Fiberglass boot lid
Lexan rear windshield and rear side windows
Aluminum-Magnesium sump guard
Interior:
Innovate Motorsports DB-Blue gauge kit (wideband lambda)
STRI DSD-CS oil temp gauge
STRI DSD-CS oil pressure gauge
Six pole SPARCO killswitch
SPARCO Pro2000 seats
Sabelt aluminium seat fastening consoles
4 point Sabelt safety belts
Flocked dashboard
I’m giving away lots of spare parts with this package, including wheels (13”, 14”, 15”), a front end, some other chassis/cabin panels, doors, a pair of halfshafts, transmission, starter, etc.
The car is located in Budapest/Hungary. Asking price is 10.500 EUR.
1985 AE86 GT Coupe (Zenki) Racecar For Sale
Re: 1985 AE86 GT Coupe (Zenki) Racecar For Sale
That's a really nice Levin you got there. Good luck with the sale man. The next owner will be happy.
if only in the US
Very nice. By the way, in the US, "coupe" means trunk version and "hatch" means hatchback like yours.
