SALE ONLY !!!
I have my 1984 Toyota Corolla SR5 hatchback that just had its new 4age motor rebuilt and paired with Mikuni 44phh dual carburetors. car is black/white panda (sprayed) and is my daily driver. i have the CA title but was salvaged due to small hit in the rear. the accident ocurred 8/27/99 by first owner who was hit rear passenger side. insurance did not want to pay for repairs since the car was not worth the cost of damage. thats the reason for it being salvaged out and the owner took the reimbursement but had to salvage out the title if he decided to keep it. im the 2nd owner. I have Autocheck report i can include with sale as well. my car will be sold with bill of sale. The car has been in my name since 2011. Car is my daily driver so miles will slightly be going up. fun car to drive. i do not abuse of any of my vehicles.
Mileage is 320k on chasis. Motor and carbs have less than 2k miles.
Price set at: $4000 !!!!!
text 404-422-6550
here is a list of some of the parts that have been installed to it:
- 4age blue top motor (rebuilt approx 2k miles on it)
- Mikuni 44pph Dual carburetors (rebuilt w/ new main, pilot jets, gaskets, fuel pumps)
- AEM AFR guage
- OBX-R adjustable cam gears
- ARP head bolts
- ARP head studs
- supertech titanium dual valve springs
- supertech valve seals
- cometic head gasket
- balanced block with lightweight crank pulley
- Exedy stage 1 clutch
- Exedy light weight flywheel
- new GTS clutch master cylinder
- new GTS clutch slave cylinder
- SS brake lines
- SS clutch line
- Holley fuel pump (mounted under car near tank)
- new FPR with oil filled guage
- new Mishimoto radiator
- aftermarket radiator hoses
- new alternator
- new water pump
- new starter
- TRD spark plug wires
- new distrtibutor cap & rotor
- new Megan Racing motor mounts
- new Megan Racing transmission mount
- MSD 6al
- MSD coil blaster
- MSD tach adapter
- T3 test pipe with with welded in flex pipe
- OBX-r wrapped headers
- Greddy DD exhaust with burnt tip
- Tokiko blues shocks all around
- Eibach lowering springs
- Poly bushings all around
- adjustable panhard bar
- SR5 rear end with Wier Performance spool
- T3 Traction brackets
- Prothane bushings all around
- 4 link kit
- New timken inner & outer wheel bearing all around
this is what I can think of on top of my head. there are much more parts that are on the car.
