FS: 2007 Toyota Camry
JohhnyD86
Postby JohhnyD86 » Wed Oct 22, 2014 10:18 pm
Hello
I am selling a 2007 Toyota Camry CE 5-spd automatic 4 cylinder 2.4L.
It has 195,xxx miles.
Asking Price $6900 OBO
Original owner
Clean title in hand
Passed smog inspection. (copy of smog paper for dmv)
CARFAX vehicle history report available upon sell.
All the dash warning lights and gauges working properly.
Airbag light appears momentarily and goes out upon starting the vehicle working properly.
Headlights, parking lights, tail lights and brake lights is working properly.
The vehicle is in original condition and no modification. The exterior color is sliver and interior is gray. Air condition is blowing cold. I work at Lexus dealership so I perform all the repairs and maintenance to this vehicle.
Maintenance and services was recently performed at 195,xxx miles.
Performed oil and filter service with factory oil filter and Toyota engine oil 5QTS 0W-20.
Performed fuel induction service
Clean throttle body service
Performed brake flush and refill to proper level
Performed power steering fluid exchange and refill to proper level
Replaced front wiper blades.
Resurfaced front rotors due to brake pulsation.
Replaced valve cover gasket due to oil leak.
Replaced PCV valve and ventilation hose in conjunction with valve cover gasket replacement.
Replaced New Camry Gray Floor Mats.
Performed 4 wheel alignment. (copy of alignment paper)
Performed battery test good rated 640/593 measured CCA, voltage 12.51v (I have test report)
Performed starter test cranking normal voltage 11.07v (test report)
Performed charging system test no problems. No Load Test 13.95v Load Test 13.71v (test report)
Replaced battery on May 2014.
Replaced new engine air filter.
TIRE TREAD
Front tread depth 9/32 Rear 6/32
215/60R16 Landsail LS288
Brakes at front pads 9MM Rear pads 6MM
Factory tire F34PSI R34PSI
The BAD
Minor fender bender left front fender and bumper dented due to someone backing into the car while it was parked in the street(I know how do you hit a parked car right?)
The radio is inoperative.
Missing right rear wheel hub cap.
If you have any question about the vehicle please feel free to contact me by phone or text at 858-218-4957 ask for Johnny. Thank you for your time
http://sandiego.craigslist.org/csd/mcy/4805614332.html
JohhnyD86
Re: FS: 2007 Toyota Camry
Postby JohhnyD86 » Sun Nov 09, 2014 3:15 pm
Bump
JohhnyD86
Postby JohhnyD86 » Thu Dec 11, 2014 12:07 am
Bump...Still for sale!
