1986 toyota corolla ae86 gts
Posted: Tue Oct 28, 2014 5:21 pm
1986 Toyota Corolla Gts
Rebuilt engine:
Machine work done locally at Costa Mesa R&D by John
Large port with 11:1 compression pistons(JE Pistions)
New oem valves
All new components in motor including new Web Cam 577 Grind/bearings/water pump etc.
New clutch and lighten flywheel
Hks adjustable cam gears
Fresh paint on both valve covers/oil pan(no leaks)
Original trd header
Injen short ram intake system
Hks air filter(pictured is the old injen filter, now has a green shroom)
Transmission in great shape
New ign wires
New aw11 distributor
New motor mounts
New transmission mount
New oem starter
Koyo aluminum radiator
Has a test pipe installed with v-band flanges in place of cat
One piece exhaust from there-on after
Oem manual steering rack
Supposebly has a Kaaz two way from previous owner(Never verified, but locks hard)
New front wheel bearings
New brake hoses
Has slotted and drilled rotors
Front control arms extended about an inch along with tie rods
Has kyb/agx shock combo
Trd springs
Battle verson pan hard
Gas tank cleaned and inspected
Full roll cage
Front engine bay is painted Toyota Pure White
Gutted interior(Still have most interior panels)
Has a no name bucket seat(side mounts are welded to the chassis)
Has a dash cover
New Windshield
All windows have been professionally resealed
Recently painted less than a year ago two tone red/black
Front end is replaced with a removable stainless steel radiator support
Sparco steering wheel with some famous signatures
Nrg quick release
Crow enterprises 6 point harness
Omori 10k tachometer(jumps around at higher rpm)
Headlamps are welded stationary(does not retract)
Body in great shape
Kouki front bumper with kouki corner lamps and emblem
Zenki rear bumper
Sprinter tail lamp lenses
Carbon gt-like side view mirrors
Most likely more stuff as well but can't recall
Overall a super fun car to drive. Selling due to lack of time and would rather see the car go to someone who would put it to good use. Drives strong, and pretty easy to drive. I personally never had the chance to take it on the track.
Cons:
Salvage title(although no body/frame damage) Price is adjusted for this.
No heater or air conditioning
Speedo does not work.
Looking to sell for 6800 with 14' Appliance mesh or 7500 with Rota grids 15x8(with brand new 225 Nt01's)
Not looking to trade.
dont mind the paint on the last picture, it has been repainted since. The junky cable end has been replaced as well.
Rebuilt engine:
New oem valves
Original trd header
New ign wires
New motor mounts
New oem starter
New brake hoses
Trd springs
Full roll cage
Has a dash cover
New Windshield
Nrg quick release
Body in great shape
Zenki rear bumper
Cons:
