FS: Your New daily Driver AE92
Posted: Fri Feb 01, 2013 6:30 pm
1990 Toyota Corolla four door sedan
Engine: 4AF 1.6L twin cam 4 cylinder, EFI
Transmission: 3 Speed Automatic
Exterior Color: Silver Metallic (clear is peeling off) 7/10
Interior Color: Gray 9/10
Heater: Yes, in good working order
AC: Yes, has been retrofitted to R134 but needs to be recharged
Mileage: 323,xxx
Tittle: Clean tittle. Registered under my name. Have Pinkslip in hand
Smog: Passed one month ago. Have papers if needed
List of Components replaced within the last 8 months:
Timing Belt (oem Toyota),
Engine drive belts, all 3 (new)
Valve Cover gasket (oem Toyota)
Intake Manifold and Throttle Body gasket (oem Toyota)
Exhaust Manifold gasket (oem Toyota)
Freeze plugs (oem Toyota)
Tranmission Pan gasket (oem Toyota)
Spark Plugs (oem Toyota)
NGK Spark Plug wires
Radiator
Left Rear wheel bearing
Rack and Pinion inner and outer tie rods, with bellows boots (New)
Rear Engine Mount, most difficult to replace
Vehicle has been equipted with a 2000 Corolla Suspension Upgrade
2000 Corolla Monroe Sensamatic Struts
2000 Corolla M2 Performance Springs
XXR 501 15x8 +15 Rims, With wheel locks,lug nuts
Bridgestone Potenza Tires
Brake Fluid Exchange
Transmission Fluid Exchage
Coolant Exchage, has Toyota Pink Fluid
Alignment
Vehicle rides smooth, not bouncy at all. Will get slight rubbing if turning hard. Fenders have been rolled. No over heating, If you are interested text or call me at (3two3) 71nine- 63onefive. Located in Palmdale, CA
$2000 obo
clear on hood peeling
Mileage: 323,xxx
Radiator
Alignment
$2000 obo
