Selling my clean title true gts 86 Toyota corolla. I did a 1uz motor swap but am separating. The subframe is modified to bolt straight to 1uz.
Aluminum radiator / electric fans, relocated oil filter, oil cooler
Celica supra rear end, new bearings w/ welded diff solid pinion spacer
Suspension:
Front custom coilovers w/ 8k springs, newer struts, tein camber plates
T3 knuckles, T3 NCRCA, Megan tension rods, Factory swaybar w/ new end links, Poly control arm bushings
Manual steering rack with Quaife quick response kit, power steering tie rod ends
T3 5k rear coilovers, ST rear swaybar, adjustable 4 links, T3 Panhard bar, T3 traction brackets
Brakes:
RX7 front brake kit with drilled / slotted rotors, ss lines
Drilled / slotted rear rotors with new celica supra calipers, ss lines
300zx Master Cylinder and Tercel brake booster (much thinner than oem)
ISIS handbrake w/ SS lines
Everything else:
T3 Hatch bar, custom rear strut brace
I stripped interior and engine bay, spot welded all seams, primed and painted inside white and engine bay metallic purple
Fiberglass fender flairs molded to the car
Front wheels are Rota's 15x9.5 with 205/50 Nitto NeoGen, Rear are Basset Steelies 15x10 with Kuhmo 225/50
New gas tank (not installed yet)
Oil pressure and water temp gauges
NEW DRIVER DOOR HINGES!!!!!!
Body is in pretty good shape there is a little more rust to finish on the pass side rocker. Windshield is cracked but rest of glass is intact.
I drove the car with current suspension/steering setup for about 100 miles before the swap, it felt awesome and similar to a go cart.
asking $5000 and will consider offers
Can email or text me about the car 423741556one
Clean Title I have a lot of time and money tied up in the car and want to keep it but she will be happier not sitting in storage.
Consider trades for 1 or 2jzgte or ls v8 engine swap jdm 18x9.5+ wheels etc
