Engine
High Compression Redtop block with rebuilt Bluetop head for intake ports and air flow
ARP head studs
TRD .8mm head gasket
New valve cover gasket
New starter
New alternator
New water pump
New distributor cap and rotor
NGK spark plug wires
Home made intake with hks mushroom filter
GSP radiator
2 10in electric fans
Some headers
2.5in semi straight pipe exhaust
walboro 255 inline fuel pump
Transmission
T50 gts transmission
Exedy stage 2 3puck clutch
F1 lightweight flywheel
SS clutch line
80w90 lucas synthetic gear oil
Suspension
Has full front crossmember, spindles, brakes, lca, and sway bar from a gts ae86 corolla with a real ae86 manual rack and pinion, so no more pitman and idler arm set up.
T3 front coilovers with T3 top hats
Some ebay coil sleeves in the rear
Front strut bar
T3 RCA
Has dual rear sway bar link in the rear
Welded diff so its drift friendly
Exterior
2 Tone old school paint job
Door mounted mirros
Bmw m3 trunk wing
Custom roof wing
Car has flares but brand is unknown
Solex locks all around, including gas door
Front end quad headlight conversion, was originally square headlights
Interior
Grant wood grain steering wheel
JDM white subway drifto ring
JDM Seiko flower shift knob
Drift knob
Gts front seats
Reupholstered blue suede doors
Dash mat
Ae86 arm rest with cup holder inside
Cool fan boy dmax replica floor mats
Wheels
14x6+12 and 14x6.5+23 longchamp wheels, believe it or not these are longchamp wheels that look like the advan a3a their not
Im sure theres more but this is all I can remember for the moment, now onto the pics
