1985 cressida
1985 cressida
i have a 1985 cressida that i want to sell for $3,500. the car has 213xxx miles. i just registered it last July and i also got new plates for it. i just did a 5 speed swap two weeks ago with new Exedy clutch kit and new OEM flywheel bolts. the resurfaced flywheel, w58 transmission, front drive shaft, and shifter are all from a 1989 supra non turbo. the clutch master and slave cylinders are brand new and so is the hardline from master to slave cylinder(no rubber line). i also replaced the transmission fluid twice(to get rid of any old fluid). the transmission shifts like a new one with no issues at all. the clutch pedal is from an 83 supra and the brake pedal is the stock one that i cut. the leather shift boot is an aftermarket one. i also replaced the following parts with brand new ones. driver side outer tie rod, passenger side inner tie rod, front brake pads with oem Toyota, front rubber brake lines, right rear wheel bearing and seals, and all of the fluids(brakes, engine oil, coolant, rear diff). its lowered on stock springs that i cut(1.5 coils off all around) with KYB silver shocks and strut inserts. the wheels are 17x8 +25 off set XXR 006 with 225/45/17 tires. 25mm bolt on wheel spacers are also ordered. i also built a 2.5 inch cat back with mandrel bent tubing that i cut and welded together with resonator and N1 style ebay muffler. the car runs good, a lot of bottom end power since the exhaust was built. also have 5k HID headlight bulbs and LED dome light bulb. i also have a brand new set of NGK spark plugs that i have not installed yet. the exterior is bluish silver with a few small dings and the moon roof has rust. the interior is light blue cloth. the dash has no cracks and all the power windows work. dont know how to upload pictures, so text me for pictures. im located in San Diego, CA. my number is 619-274-4261. my name is Roger.
Re: 1985 cressida
Pics please
- idreamofdrifting
