rolling 1985 toyota corolla coupe sr5 shell with gts stuff
Posted: Thu Nov 28, 2013 12:10 pm
hello there my fellow ae86 enthusiasts i have my sr5 up for sale the reason being is cause i dont have the money to finish and the parking spot it sits in needs to be used for other vehicles. i first got the car up in santa rosa, california it had not been registered since 2009 but i paid of the back fees so all it needs is a smog. here is a list of things about it
-BAD
-it had a salvage title
-the dash is cracked pretty bad
-the interior is stripped (no carpet,door panels,headliner,heater of AC,back seat is gone
-the left side quarter panel where is unlaps the trunk section has surface rust do to a crap bondo repair
-the left side tail light has a crack in it
-sits on cut springs
-GOOD
-the body is relatively straight
-GTS gauge cluster
-GTS underdash harness has been installed
-GTS engine bay harness has been installed
-GTS zenki rearend has been installed
-has supra rims on it
-manual rack from an MR2 has been installed with T3 adapter
-tie rods ands have been upgraded to T3 outer tie rods
-EXTRAS
-rebuilt bluetop 4AGE (king brand connecting rod and crankshaft bearings,Eristic brand pistons,Eristic brand rings. OEM water pump,viton valve seals, recut valve seats
-T50 GTS transmission with bell housing
-GTS driveshafts
- GTS engine wiring harness
-OEM oil cooler
-stock radiator
-all emissions equipment
-polish RWD intake manifold
-megan racing motor and transmission mounts
-megan racing 2 inch lowering springs
-box of random corolla and aw11 parts
-red top high comp pistons with CX racing connecting rods
i am asking 1200 for just the shell with all the GTS wiring in it and rearend, 800 for just the stuff under the extras category or 2000 for everything. this car will be up for 3 weeks if its not sold by then unfortunately as much as i love the car im gona have to take it to the scrap yard. my number is 831-594-6800
-BAD
-GOOD
-GTS gauge cluster
-EXTRAS
-GTS driveshafts
-OEM oil cooler
-stock radiator
