1985 Rebuilt Toyota Corolla GTS AE86
Posted: Sun Jan 12, 2014 5:25 pm
After many years I have decided to sell my beloved AE86. Unfortunately I do not have the time to work on this project and I hope whoever buys this has fun with the build. The engine is fully rebuilt with OEM parts and Tomei titanium springs. The build was done by a garage called Illegal Garage. The body has been repainted by Angles Auto Body. I have Kouki front and rear bumpers, unpainted, which are not shown in the picture. There are a few parts that need to be placed together to get the car running, and I have all the major components (detailed list below). I have two wheels and you would need to provide two more in order to tow it.
Some tasks that need to be completed include:
1) plug in the wiring harness (has already been fitted into the engine bay);
2) install fuel rail and injectors;
3) put on the intake
List of parts included:
Project Mu Camber Plates
Tokico HTS Full Stroke Shock
T3 Front coil over conversion
T3 TC rods
T3 Roll center adjusters
Battle Version 4 Link
Battle Version Panhard
TRD Shifter
TRD front sway bar
TRD Headers
TRD 2 Way LSD
TRD 6k Rear spring
TRD Spark plug wires
Single Piece Drive shaft
Illegal garage Clutch
Flywheel
Axle housing
1 rear axle
Kouki bumper lamps
Kouki Front bumper
Kouki rear bumper
ΒΌ glass
LSD bearings
Ring and pinion
Pinion spacer
Connecting rods
Valve covers
Water pump pulley
Fuel rail
Oil filter gaskets
Oil filter
Water pump
Water pump o rings
Bypass pipe o ring
Water reservoir
Water reservoir bracket
Cat back muffler
Cat converter
Heater core
Heater hose
Lower radiator hose
Brake cables
E brake cable
E brake cable pins
Radiator cap
Oil cooler
Oil cooler hose
Tensioner spring
Tensioner
Oil presser sending unit
Rear Muffler hangar
Muffler donuts
EGR bolt
EGR Bung
Bung Tap
Power steering delete fittings
Used EGR
Used EGR main pipe
Thermostat
Thermostat gasket
Water temp sensor
Water gauge sensor
Timing belt timing gear
Rear EGR pipe
Upper radiator hose
Front wheel bearings
Front wheel bearing seals
Brake pads Front
Brake pads Rear
Front rotors
Rear rotors
Radiator support
Hood prop
Seat brackets
Window run
Tail lamp gasket
Battery tray
Battery bracket
Small bumper bolts
Large bumper bolts
PRICE $5275 obo
Car located in San Jose, Ca
Please contact me via email at hungwensun@gmail.com for any questions, serious inquiries only. Thanks for looking!
See pics here: http://imgur.com/a/qh69H#0
See craigslist post here: http://sfbay.craigslist.org/sby/cto/4284618787.html
T3 TC rods
TRD Shifter
TRD front sway bar
TRD Headers
TRD 2 Way LSD
TRD 6k Rear spring
Flywheel
Axle housing
1 rear axle
Kouki bumper lamps
Kouki Front bumper
Kouki rear bumper
ΒΌ glass
LSD bearings
Ring and pinion
Pinion spacer
Connecting rods
Valve covers
Water pump pulley
Fuel rail
Oil filter gaskets
Oil filter
Water pump
Water pump o rings
Bypass pipe o ring
Water reservoir
Cat back muffler
Cat converter
Heater core
Heater hose
Lower radiator hose
Brake cables
E brake cable
E brake cable pins
Radiator cap
Oil cooler
Oil cooler hose
Tensioner spring
Tensioner
Rear Muffler hangar
Muffler donuts
EGR bolt
EGR Bung
Bung Tap
Used EGR
Used EGR main pipe
Thermostat
Thermostat gasket
Water temp sensor
Water gauge sensor
Rear EGR pipe
Upper radiator hose
Brake pads Front
Brake pads Rear
Front rotors
Rear rotors
Radiator support
Hood prop
Seat brackets
Window run
Tail lamp gasket
Battery tray
Battery bracket
Small bumper bolts
Large bumper bolts
PRICE $5275 obo
