hey everyone I'm Looking for a 1 piece Driveshaft for ae86 anything lighter than stock what do you have.. aluminum, chromoly, carbon? let me know pleassee thanks
located los angeles,ca
I also have a zenki rear end open diff, would like to get a zenki or kouki rear end w/ LSD, or if any one knows of a shop in social that can install an lsd in my open diff third member thad be perfect, i don't want to cut the axles myself to fix an led….
if anyone is selling or knows where to get one please txt me @702-449-9094 I'm located socal los angeles thnx
AE86 DRIVESHAFT TAILSHAFT 1 piece, & LSD
Re: AE86 DRIVESHAFT TAILSHAFT 1 piece, & LSD
New 1 piece drive shaft $400 shipped
Max
Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
Maxfrommisawa@aol.com
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
Sweet that sounds ok what is it made of
Lightweight steel
13lbs 14 oz iirc
Max
13lbs 14 oz iirc
Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
I have a one piece driveshaft 225 shipped u can contact me at 8645084739
I sell Carbon Fiber Drive shafts....One piece...stronger than steel or aluminum..and any metal shaft smaller than 3 inches in diameter and longer than 50 inches will exceed the max critical speed at 6900 rpm and become unstable, flex, twist and break....anything smaller in diameter than 3 inches has a lower critical speed for example 2 3/4 diameter like my carbon shafts in steel or aluminum will be unsafe at 5800 rpm...here a picture of my shafts in carbon at 2 3/4 inch diameter and a metal shaft someone had which was made using the OEM u joints at the same diameter of the stock shaft which is about 2 1/2 inches...2 1/2 inch one piece shaft at 50 inches which is the length of our shafts is about 4900 rpm...
heres my write up on the shafts and peoples responses who have bought them...they are more expensive than metal one piece..but quality is 100% better...as well as performance and strength is proven.
viewtopic.php?f=22&t=2648
