Used factory oil cooler lines ae86
Anyone have an stock gts oil cooler lines,
Re: Used factory oil cooler lines ae86
Hey yasu, I've just used the appropriate inner diameter sized transmission oil cooler lines. Pretty cheap at auto parts stores. I've had to replace mine before in the past.
tchybrid wrote:Hey yasu, I've just used the appropriate inner diameter sized transmission oil cooler lines. Pretty cheap at auto parts stores. I've had to replace mine before in the past.
+1111111111111
I have uses trans cooler lines in the past. I wanted to see what the oem lines are made out of.
I have them.... =) come get it......
BoRoYaSui wrote:I have uses trans cooler lines in the past. I wanted to see what the oem lines are made out of.
I believe they are just rubber lines like they use for trans cooler lines.
