How to Refinish Window Moldings
truenoboy
Postby truenoboy » Mon Mar 09, 2015 8:02 pm
Do you guys have any tips or tricks on how to refinish window molding? I hoping to remove the black on mine to repaint them.
ritz
Re: How to Refinish Window Moldings
Postby ritz » Tue Mar 10, 2015 8:28 am
I used a razor blade to get rid of the rubber material. For what I couldn't get off, I'd heat it up with a small torch, and then went back at it with a razor.
Use caution, it get's hot.
tchybrid
Postby tchybrid » Tue Mar 10, 2015 10:09 am
has anyone thought of using PlastiDip to refinish the moldings?
marin86
Postby marin86 » Tue Mar 10, 2015 10:11 am
Don't use plastidip unless you just want it to peel off
morgan
Postby morgan » Thu Mar 12, 2015 9:12 am
Yeah the spray plastidip looks like poo after a year and peels
My turd of an 86
20v swapped 86 write-up
ae86Stig
Postby ae86Stig » Sun Jan 17, 2016 6:25 pm
Being a glass guy I've answered this question on more then one occasion. Once I got some vinyl from my local sign shop our clients reviews went through the roof. All different thicknesses and finishes to meet your needs. As most older mouldings are metal heat gun/torch works great to delaminate the old. Methyl hydrate always on hand since is used to cut lami glass. Acetone etc etc sure will work. Then a simple process to cut strips needed and apply. Use something soft that's non abrasive to hone to perfection. Viola! Brand-new results. Can color match if wanted desired effect and so on. Hope this helps
Sent from my LG-P769 using Tapatalk
Postby Deuce Cam » Mon Jan 18, 2016 10:10 am
That's a great idea. A search reveled this video (sorry I don't know how to embed): https://www.youtube.com/watch?v=9-GWmfDnDhs
I wonder how it would hold up.
ae86Stig
Postby ae86Stig » Mon Jan 18, 2016 10:32 am
Deuce Cam wrote:That's a great idea. A search reveled this video (sorry I don't know how to embed): https://www.youtube.com/watch?v=9-GWmfDnDhs
The only concern with this application is the olfa knife and it razor blade. As ll chrome mouldings have a clear wrap to it. Or body side of the trim most have rubber to contact the body. Be worried of a hack job. As mentioned being a glass guy trained not to nick or scratch the pinchweld for obvious reasons. I'm as anal as they come, diy for sure lol. Definitely will be refurbishing my window trim all around, belt mouldings etc. As I have no peel on my ae will over wrap .... one day lol
Great vid/resource. Embedding worked too![emoji106]
Lastly, so many gauges and quality of vinyls, you get what you pay for and like anything it's all in the prep.
mad_86
Postby mad_86 » Fri Feb 05, 2016 1:33 pm
clean up the molding, light sanding, prime it then purchase trim molding Spray can, Autozone and Orielly have them
