DIY 4 link
marley4us
DIY 4 link
Postby marley4us » Thu Feb 28, 2013 12:13 am
I found this on 86garage.com I think its the same part numbers as club4ags old one... hope so.
"Ok so after posting in the drift setup thread I went digging for all of the info on my four link. Enjoy!
You will need these parts to make the four link. I ordered them from speedway motors and mccaster-carr. I bought all of the washers and nuts from them even though they cost a little more so if you can find them for less go for it.
parts from speedwaymotors.com for the four link
2 91034158-15 Aluminum Tie Rod Sleeve, 5/8", 15" $7.95 EA
2 91034158-7 Aluminum Tie Rod Sleeve, 5/8", 7" $7.95 EA
1 1756048-LH JAM NUTS 5/8", STEEL 6/PACK $3.45 EA
1 1756048-RH JAM NUTS 5/8", STEEL 6/PACK $3.45 EA
Parts From mcmaster-carr.com
4 2458K171 CARBON-FIBER RACE BALL JOINT ROD END, 5/8"-18 RH MALE SHANK, 7400 POUND LOAD CAPACITY $13.72 EA
4 2458K172 CARBON-FIBER RACE BALL JOINT ROD END, 5/8"-18 LH MALE SHANK, 7400 POUND LOAD CAPACITY $13.72 EA
8 6381K47 ALLOY 932 (SAE 660) BRONZE SLEEVE BEARING, FOR 1/2" SHAFT DIAMETER, 5/8" OD, 3/4" LENGTH 1.24 EA
2 packs 91166A290 METRIC DIN 125 ZINC-PLATED STEEL FLAT WASHER, M12 SCREW SIZE, 13MM ID, 24MM OD, 2.3-2.7MM THICK $6.25 EA
If you build it this way the total comes to around $170 $150 without nuts and washers"
1994 4runner (The truck)
KonaTrueno723
Re: DIY 4 link
Postby KonaTrueno723 » Thu Feb 28, 2013 12:55 am
I'm glad you found the part #'s for this DIY Ian..great job!
87 GTS Coupe
72 Blown 6-71 Pro Street Vega
jromo04
Re: DIY 4 link
Postby jromo04 » Thu Feb 28, 2013 1:00 am
Nice, can i please see some pics. Thanks
ga_goosh
Re: DIY 4 link
Postby ga_goosh » Fri Mar 01, 2013 3:48 pm
jromo04 wrote:Nice, can i please see some pics. Thanks
here is the pic when i made mine. of coarse these where made with the 14 inch long sleeves and after adjusting my pinion angle i found out that the 15 inch sleeves are the correct size to use.
I <3 my AE86
4AG Manual
AE86 FSM
NC Panda
Re: DIY 4 link
Postby NC Panda » Sun Mar 03, 2013 4:06 pm
Yes! Thank you!
LongGrain
Re: DIY 4 link
Postby LongGrain » Sun Mar 03, 2013 4:08 pm
anyone of you dudes who are making these ever thought about using bushed ends on one side? Thought it would be more popular but I dont see many dudes doing it.
KonaTrueno723
Re: DIY 4 link
Postby KonaTrueno723 » Mon Mar 04, 2013 4:25 pm
LongGrain wrote:anyone of you dudes who are making these ever thought about using bushed ends on one side? Thought it would be more popular but I dont see many dudes doing it.
I'd like to do something like this to my DIY links. When I do get around to it, I'll post..presently working on something else on my car at the moment :?
87 GTS Coupe
ga_goosh
Re: DIY 4 link
Postby ga_goosh » Tue Mar 05, 2013 12:10 pm
I used bushed ends on one side. i got a set of bushed ends from speedwaymotors.com.
I had to use 5 washers to get a tight fit.
I <3 my AE86
4AG Manual
AE86 FSM
KonaTrueno723
Re: DIY 4 link
Postby KonaTrueno723 » Tue Mar 05, 2013 9:34 pm
Excellent ga_goosh! Thats exactly what I needed for my links..thanks!
Last edited by KonaTrueno723 on Thu Mar 07, 2013 11:52 am, edited 1 time in total.
87 GTS Coupe
ga_goosh
Re: DIY 4 link
Postby ga_goosh » Wed Mar 06, 2013 11:57 am
KonaTrueno723 wrote:Excellent ga_goosh! Thats exactly what I need..thanks!
also i forgot to mention the threads are a little different. the sleeves are 5/8 x 16 and the bushed ends are 5/8 x 18. they will thread in but they are tight
I <3 my AE86
4AG Manual
AE86 FSM
KonaTrueno723
Re: DIY 4 link
Postby KonaTrueno723 » Thu Mar 07, 2013 6:55 pm
Yeah I'll keep that in mind, making a call to them tomarrow for a set of 4..
87 GTS Coupe
BIG WHITE
Re: DIY 4 link
Postby BIG WHITE » Thu Apr 18, 2013 7:08 pm
so i was adding everything to my cart to purchase all the above items and i noticed the washers are in packs of 100???? how man do i need. and even then why 2 packs. 200 washers seems like overkill lol
KonaTrueno723
Re: DIY 4 link
Postby KonaTrueno723 » Fri Apr 19, 2013 3:19 pm
:shock: Bulk! more than what's needed..I'd just get these down at any local hardware place. i remembered using 4-6 washers (2-3 for ea side depending) per heim joint for my diy links. Hope this helps
87 GTS Coupe
formulad11
Re: DIY 4 link
Postby formulad11 » Wed Apr 24, 2013 6:49 am
I had a lot of slop and play from this setup. If someone could find metric rod ends and sleeves or get metric conversion insterts for the rod end then that would clear up any clank clank going on under accel or decel. I eneded up just tossing these and buyin a set from t3 . Which use fk rod ends
ga_goosh
Re: DIY 4 link
Postby ga_goosh » Wed Apr 24, 2013 8:07 am
BIG WHITE wrote:so i was adding everything to my cart to purchase all the above items and i noticed the washers are in packs of 100???? how man do i need. and even then why 2 packs. 200 washers seems like overkill lol
on my set up i used 4 washers for the heim side and 3 for the bushed side. its not the best pic but you get the point. i also used some heim spacers to eliminate the use of so many washers
I <3 my AE86
4AG Manual
AE86 FSM
BIG WHITE
Re: DIY 4 link
Postby BIG WHITE » Sun Apr 28, 2013 12:59 pm
Thanks for the replies. Im going to search around a little more to see if I can find a better solution so I wont have to use so many washers. I will post it if I find anything
Clutch_Kick_Lou
Re: DIY 4 link
Postby Clutch_Kick_Lou » Mon May 27, 2013 1:00 am
Awesome, I was going to buy T3s next month and Id rather build my own suspension any day of the week. Thanks for this, do the rods come in that goldish color? If so, even better lol
By the way, how's the difference over stock?
☆ ☆ ☆ BUZZKILLER ☆ ☆ ☆
Straitup D
Re: DIY 4 link
Postby Straitup D » Tue May 13, 2014 10:11 am
i was not able to find the 7in bars for the 4 link
3tcPower
Re: DIY 4 link
Postby 3tcPower » Thu May 15, 2014 11:20 am
So, would it be possible just to use 4 bushing ends instead of the ball joint?
http://www.speedwaymotors.com/Speedway-Forged-Steel-4-Bar-Rod-Ends-5-8-18-RH-Thread,25122.html
Also, could these bushing ends be used instead of the ball joint on the DIY panhard also? Seems like its a straight forward change.
3tcPower
Re: DIY 4 link
Postby 3tcPower » Thu May 15, 2014 11:22 am
Straitup D wrote:i was not able to find the 7in bars for the 4 link
http://www.speedwaymotors.com/Aluminum-Tie-Rod-Sleeve-5-8-Inch,2087.html
The option for 7" is just past 24", towards the bottom of the drop down.
Straitup D
Re: DIY 4 link
Postby Straitup D » Thu May 15, 2014 11:37 am
yeah i saw that after further investigation!
ga_goosh
Re: DIY 4 link
Postby ga_goosh » Mon May 19, 2014 7:41 am
yes it will work and yes it can be used on the panhard bar as well. i am using these on my 4 link and have had them on for about 3 years now at least
I <3 my AE86
4AG Manual
AE86 FSM
Blade
Re: DIY 4 link
Postby Blade » Sun Jan 17, 2016 7:19 am
I have been looking into this now for a bit, and I'm mostly concerned about the 12mm to 1/2" of around the bushing. Don't you want it to fit tighter? Also, if you are using a reducer sleeve anyways, why not just get the 1/2" joints to begin with and not need to reduce it? Or even just drill it out and get 1/2" bolts?
