my DIY 20v into an 86 write-up
morgan
Re: my DIY 20v into an 86 write-up
Postby morgan » Fri Oct 30, 2015 6:21 am
yes, if you swap to all BT electronics.
ecu, map sensor, iat sensor, BT engine harness merged with 86 harness(see wiring section or buy one)
...and thanks
My turd of an 86
20v swapped 86 write-up
allencr
Postby allencr » Sun Nov 29, 2015 1:51 pm
Very good Pics & Words. Thanks. Just skimmed and I'll really have to really read it fully & the Moto-P epic saga again.
Hows the fork.
hachirokufan
Postby hachirokufan » Mon Jan 18, 2016 10:12 am
saiGone wrote:
hachirokufan wrote:Probably a stupid question buuuuut I want to clarify something that's been bugging me about this swap. For someone with an SR5, can someone wire the engine harness' so that you don't have to rewire the whole damn car?
You will still need to add wires for a fuel pump going to the back as well as under-dash. So no? IMO
Bump from the dead!
Got in touch with Tweak'd performance, and the harness they provide comes with these wires. So anyone with an SR5 can be plug and play without rewiring the whole car
jpainbringer
Postby jpainbringer » Mon Aug 29, 2016 11:02 am
Wonderful write up. With your help, I was able to achieve this...
https://youtu.be/krW4WH3U2cU
morgan
Postby morgan » Fri Sep 02, 2016 8:52 am
jpainbringer wrote:Wonderful write up. With your help, I was able to achieve this...
awesome! glad it helped
My turd of an 86
