4age into sr5 help with mounts?
Be nice to others.
Darksied101
Postby Darksied101 » Fri Sep 13, 2013 12:12 pm
I have heard that i need brackets other than motar mounts to drop a 4age into my sr5 but not sure if true. can anyone tell me exactly what is needed in order to bolt the 4age into my sr5 ?
carbd7age
Re: 4age into sr5 help with mounts?
Postby carbd7age » Fri Sep 13, 2013 5:28 pm
The mounts are 100% exactly the same.
Knockoff Crew member #0001
Darksied101
Postby Darksied101 » Sat Sep 14, 2013 1:56 pm
oh okay cus idk why i was hearing that i needed brackets
carbd7age
Postby carbd7age » Sat Sep 14, 2013 3:55 pm
Dunno. You may want to find a GTS bellhousing to put the slave cylinder on the opposite of the exhaust.
krammit the frog
Postby krammit the frog » Fri Sep 27, 2013 7:31 pm
All accessory brackets are different (ac, ps, alternator). The engine mounts themselves and engine mount brackets that come off the engine block are identical between 4ac/4ag.
You can forego all those brackets by eliminating ac and power steering (best idea in my opinion). That also means you only have one belt to worry about, and it makes it that much easier to change. Also means you have that much less parasitic loss in our already gutless motors. For the alternator, you just need some way to provide tension, and I think NST makes an aftermarket tensioner in case you can't find a stock gts alternator tensioner.
Darksied101
Postby Darksied101 » Mon Oct 07, 2013 10:45 am
Ohhh okay awesome thanks alot!
