Block type help
FrgtnKnt
Block type help
I own an 88 MR2 supercharged, and am planing on building the engine. So I've been reading about the 3rib and 7rib blocks, but I cant seem to find any solid answer on what Year they switched to the 7rib. I've read that they switched in 87 some in 88 and some say that all GZE's are 7rib. I currently am Deployed so I can't really walk out to my car to verify, so if someone could be kind enough to let me know It would be much appreciated.
Re: Block type help
FrgtnKnt wrote:I own an 88 MR2 supercharged, and am planing on building the engine. So I've been reading about the 3rib and 7rib blocks, but I cant seem to find any solid answer on what Year they switched to the 7rib. I've read that they switched in 87 some in 88 and some say that all GZE's are 7rib. I currently am Deployed so I can't really walk out to my car to verify, so if someone could be kind enough to let me know It would be much appreciated.
*IF* your MR2 has the original block/engine in it... it is a 7 rib block, has 42mm rod journal crank, and BIG BEEFY 42mm/20mm rods. It also will have low compression pistons.
