Help Needed with my Levin
Be nice to others.
TruenoTadhg
Postby TruenoTadhg » Sat Apr 26, 2014 9:32 am
Hi,
I've recently bought an ae111 Levin and now it is giving me trouble. :( The Check Engine light is on. It idles low at about 500rpm and is running rich. There is no Pull out of it. Its seriously down on power since I first bought it. It feels choked up. The temperature dial in the car isn't showing correct temperature either. It shows fairly low and i can tell by the smell of the engine when i stop that it is very hot.
I did a Diagnostic test on it and was getting fault code 13. (Knock Sensor)
Any help much appreciated on fixing these problems :)
morgan
Re: Help Needed with my Levin
Postby morgan » Sat Apr 26, 2014 10:59 am
My turd of an 86
20v swapped 86 write-up
Postby jondee86 » Sat Apr 26, 2014 3:06 pm
TruenoTadhg wrote:I've recently bought an ae111 Levin and now it is giving me trouble.
Sounds like your belt tensioner might be on the way out. Get the
timing belt covers off, then check the belt tension and the cam timing.
