Gts swap
Gts swap
Hey guy in doin a grs swap in my car and im curious to know if the sr5 underdash harness is the same as the gts harness thanks please reply
Re: Gts swap
The GTS contains the circuit opening relay for the fuel pump and the wiring to the instrument cluster. Keep in mind that the GTS cluster uses a check engine light as well as an additional circuit from the speedometer head to send an electrical vehicle speed signal to the ecu. In other words, you'll need a gts harness. When you acquire a GTS harness, it'll install just like the old sr5 (meaning the gts & sr5 has similar relay and a module that clip in to the same bracket) that includes the junction box on the right kick panel. I hope this help.
Re: Gts swap
All harnesses have there little differences. You will need GTS harnesses.
