daily driving with itb's
Be nice to others.
futurehachi
Postby futurehachi » Wed Jan 08, 2014 7:05 pm
Hi guys!
I was wondering what your solutions were for daily driving a car with itb's. how did you cope with the lack of an air filter?
I plan to daily my car but I cant quite figure out what the best way to solve the lack of an air filter.
Here's what I would like from you guys:
-Name your solution
-Details of how you did it
-List of materials used
-Approximate budget
-and last but not least, PICTURES!!
thanks guys!
Re: daily driving with itb's
Postby yoshimitsuspeed » Wed Jan 08, 2014 8:38 pm
This forum seems to be particularly bad about thinking running ITBs is synonymous with running open stacks. Many cars and far more motorcycles successfully run ITBs but they all run filters. So the short answer. Put filters on it. If that's not an option then just plan on rebuilding your motor more often.
As for filters here is one option.
http://mr2oc.com/showthread.php?t=44978 ... ght=filter
If you don't want to make the backplate let me know and I can get one cut for you.
Here is another one but there aren't pics of them mounted. You would need the right stack to be able to use this method.
viewtopic.php?f=28&t=9180
beyond that there are always stock boxes. Whatever ITBS you have came with some sort of air filter on it originally.
SidekickChuck
Postby SidekickChuck » Wed Jan 08, 2014 8:58 pm
I use ramair filters:
2001 Carbon Black e39 M5
flowisode_zero
Postby flowisode_zero » Wed Jan 08, 2014 10:47 pm
If you are on a budget just go to a motorcycle or ATV shop, grab some UNI filter sheets, cut out your own filters and zip tie them on. http://www.unifilter.com/accessories/
futurehachi
Postby futurehachi » Thu Jan 09, 2014 1:24 am
SidekickChuck wrote:I use ramair filters:
I like your setup. where can I get these?
SidekickChuck
Postby SidekickChuck » Thu Jan 09, 2014 3:26 am
Ebay
chemtrails
Postby chemtrails » Fri Jan 10, 2014 4:28 pm
Failure to follow these instructions can result in death, serious injury, or equipment damage.
86 Corolla
Postby 86 Corolla » Fri Jan 10, 2014 6:13 pm
I got these socks from T3. They work great.
The word ITB's and Budget don't belong in the same topic, lol.
futurehachi
Postby futurehachi » Fri Jan 10, 2014 7:30 pm
I bought some uni filters. They'll be here tomorrow!!! :)
Ava92
Postby Ava92 » Sat Jan 11, 2014 5:09 am
Silvertop i ran open and fried piston rings within 20,000km.
Blacktop had it for 30,000 km with uni socks pictured above, still comp. tests the same. Although even the sock filters really impede the noise. I think the safest way is to build a custom plenum as large as possible with a conventional cone filter.
Postby Deuce Cam » Sat Jan 11, 2014 9:12 am
Rs yasu and noby booth make bolt on plenums. Just add your own intake/filter.
DrAE86Toreno
Postby DrAE86Toreno » Sat Jan 11, 2014 10:03 pm
Will this apply for carbs as well? I don't see too many people using filters on carbs...I have sided raft mikuni with a little screen...car runs awesome motor runs great but I would like to put filter to be n the safe side
Postby jondee86 » Sun Jan 12, 2014 1:01 am
Carbs, ITB's all the same. Screens will keep out rocks and rodents, but
the small dust is the stuff that wrecks your engine, and that goes thru
a screen like it wasn't there !!!
carbd7age
Postby carbd7age » Sun Jan 12, 2014 6:53 am
I used a big Ram Air filter and plate off eBay. Pretty sure it was for a BMW 2002 you have to measure the distance from intake #2 to #3 to find what plate you need. The clips were installed facing the wrong way so I pressed them out, IN welded some threaded studs in the filter, and used 3 wing nuts to attach to the plate. For ITBs you would want a blank platw and drilling the holes out where you need them unless you can find a plate specific for your car.
Knockoff Crew member #0001
Postby yoshimitsuspeed » Sun Jan 12, 2014 12:46 pm
DrAE86Toreno wrote:Will this apply for carbs as well? I don't see too many people using filters on carbs...I have sided raft mikuni with a little screen...car runs awesome motor runs great but I would like to put filter to be n the safe side
jondee86 said it pretty well but I will second it just to stress the point.
All motors come from the factory with air filters including ITBs and carbs. It is definitely no less important for either. If it wasn't important OEMs wouldn't waste the time and money fitting every single vehicle with one.
carbd7age
Postby carbd7age » Mon Jan 13, 2014 6:15 pm
Just look at the picture i posted above of my old engine bay. I opened the hood and there are some leaves laying on the filter. No filter means that trash could easily get sucked into the motor. I worked way too hard on that damn trashcan to have it suck up crap and die so easy.
clevermr2name
Postby clevermr2name » Wed Sep 03, 2014 8:23 am
sidekickChuck - I have been emailing with Ramair through ebay and am close to ordering my filters like you have in the picture. would you be able to give me the model number of the filters that you ordered? what size stacks do you have also? thanks!
I am currently running open 3.5 inch stacks and love them so far, but I want to have the option of throwing a filter on any time I want and may end up running the filter almost always.
SidekickChuck
Postby SidekickChuck » Mon Sep 08, 2014 7:48 am
I ordered these:
http://www.ebay.com/itm/271183801819?_t ... EBIDX%3AIT
I took their dimensions and they seemed to match well against my ITBs. I dont know the spcs of my trumpets, but since they give a description of the hole sizes and space between the holes, you can determine which one of their filters will work for your application.
