Wiring:
Just received my CAN-AM box.  It's a wiring shortcut for Nissan swaps into various chassis vehicles.  It was developed by some members of
http://www.community.ratsun.net:
http://community.ratsun.net/topic/28097 ... -and-more/
I took a break from the body work to start touching the engine harness.  I originally had two engine harnesses (both FWD CA18DE Pulsar harnesses), but I cannibalized one to get good connectors.  The other I decided to map out and labeled each connector.  Then in a genius stroke, I cut the harness in half, save for the MAF and CAS shielded cables.  Did forget to label where I cut each wire on both sides of the cut though, so I had to label each ECU pin and then find the corresponding plugs.  In the end it worked out though.  I was able to eliminate roughly 5' of overall wiring on each strand and routed everything so it's not too obvious across the engine.
These are a few of the free wires in the bay (others are mostly ground wires I haven't trimmed out or those running to the ingition switch or gauges).  These go to the fuel pump relay/efi relay/efi safety relay and I haven't decided on a location for those just yet.
These are the wires that I haven't hooked up from the ECU, either b/c they're components are being eliminated, they're grounds that I still have to run (2 or 3 of the wires), or the components will be mounted right beside the ECU/in an undetermined, such as the efi relay/safety relay .
This is all the wiring that I have stored in case I need some extra length down the road, or extra plugs.
I also started working on how I'm going to finalize the in car wiring.  I picked up an S2000 Start Button and found a nice place to mount it.
I've been tidying up the wiring as I go and I decided that I didn't want to run a handful of wires across the interior to try and splice them into the existing fuse panel.  So, I purchased this:
That will be enough for room to add several items down the line if needed.  I'm probably going to make a mounting  surface for this and the relay board I have, along with any other items that will accompany these.  Then I'll put a lockable cover over them so they'll be as tamper proof as I can make them.  We'll see how that goes though.
