My Corolla... Back Again
Rue
Postby Rue » Tue May 07, 2013 8:54 pm
Quick history...
And current projects:
Celica-Supra rear end
4.56 Final Drive
Cleaned and painted 3rd member housing
All 4-link mounts, pan hard mount, and spring perches removed. I ground everything down but didn't take a pic after
Weir Solid Pinion Spacer
And machining 60mm RCA's. I was told they wouldn't fit... we'll see
"Working on cars is not what I do... it's who I am." Steve Metcalf
Rue
Re: My Corolla... Back Again
Postby Rue » Tue May 07, 2013 9:25 pm
And I forgot... new front lip
Rue
Postby Rue » Wed May 08, 2013 8:21 pm
Celica-Supra rear axle housing how it sits now
Finished 60mm RCA's today... hardware will be in tomorrow for test fit
miswuevos
Postby miswuevos » Thu May 09, 2013 1:51 am
Dude sweet beams!
and i am assuming those are not frp sideskirts but original expensive ones? :)
wHAT brakes are you using?
Rue
Postby Rue » Thu May 09, 2013 7:39 am
Yes... oem jdm side skirts. I made FC brake adapters for the front and I'm using celica-supra brakes in the rear with an s13 master cylinder
gazolorean
Postby gazolorean » Thu May 09, 2013 9:02 am
Glad to have had the opportunity to chat with you and see this thing in real life, super sick car for sure :D
kingofkings757
Postby kingofkings757 » Thu May 09, 2013 4:57 pm
YEA!!! I knew you would finally come around. Glad your back!!! :D
Rue
Postby Rue » Thu May 09, 2013 8:44 pm
Alright... so for the nay sayer that told me that 50mm rca's wouldn't fit behind a 15" wheel... you were wrong. Tonight I test fit my 60mm rca and everything fit without any unexpected problems. I'll only be able to grease the ball joints with the wheels off and the little lip on the outer edge of the lower control arm makes contact with the rotor only because I have big brakes. I just need to knock off the lip and everything will work fine. Hoping this fixes some of my suspension geometry issues with me spacing the subframe to fit the Beams. I'll be waiting until we make the new lower control arm setup to put the rca's on.
Gazolorean: You're welcome to stop by anytime. If the white corolla is in the driveway it's a sure bet that I'm home. Nice meeting you and your peoples
KingofKings757: I'll kill you!!!!!! LOL! You should be working on your swap
LongGrain
Postby LongGrain » Fri May 10, 2013 12:09 am
swap looks nice, hopefully i'll be there soon. hoping to get my engine at least mocked up for mounts this weekend.
interesting idea on the huge RCA's, I'm just hoping to be able to get away with minimal subframe spacing with custom solid mounts and a little subframe modification.
peep the build thread if you get a minute.
viewtopic.php?f=7&t=1558
Rue
Postby Rue » Fri May 10, 2013 7:50 am
Assassin10000 got away with no subframe spacing and just making his own mount brackets so it's possible
Rue
Postby Rue » Sat May 11, 2013 9:13 am
Lower control arms as they sit now
And I've been making a fixture to modify the Celica Supra rear ends. Marty at AutoComp already had a fixture for the 6.7" rear end so we're just making new parts to adapt his existing fixture to work for the 7.5" rear end.
Bought an extra 3rd member housing and started cutting
Machined a plate to mount it to his fixture
6.7" on right, 7.5" on left
marley4us
Postby marley4us » Sat May 11, 2013 8:32 pm
rue- long time man!!! such a bad ass build, and custom work! To bad we lost your old thread and everyone else s too :(
but man your car is going to be crazy!
1994 4runner (The truck)
Rue
Postby Rue » Wed May 15, 2013 8:23 pm
Lower control arm progress
JDMwhiteboy
Postby JDMwhiteboy » Fri May 17, 2013 9:41 am
Always loved this car, even for a panda. ;)
Fix my harness for me! I'll give you cookies?
Forum whore
Rue
Postby Rue » Fri May 17, 2013 12:56 pm
I'm gonna call you but I take payment in the form of Shiner Boch... ask McKenney.
I'll clean up your wiring but it means you have to drive to my house
JOshua a
Postby JOshua a » Thu May 23, 2013 2:23 pm
What's your fuel pressure set to?
Rue
Postby Rue » Tue May 28, 2013 9:58 am
Fuel pressure is at 42psi with 440cc 7mgte injectors
Rue
Postby Rue » Tue May 28, 2013 11:38 am
Zenki lip installed this weekend
John H.
Postby John H. » Tue May 28, 2013 11:00 pm
marley4us
Postby marley4us » Wed May 29, 2013 2:20 pm
hey its Ian!! man your lip looks great! It was good catching up with ya! I need to call ya and ask a question about those RCA's u had made, ;) TTYS
Rue
Postby Rue » Thu May 30, 2013 10:03 am
That I had made??? I'm too cheap for that. I made them myself.
marley4us
Postby marley4us » Thu May 30, 2013 3:45 pm
that's what I meant! lol my english has gone to crap lol!!! that you had made yourself!
grappletech
Postby grappletech » Fri May 31, 2013 3:49 pm
Looks good Aaron. I can't wait to get back to start on mine.
87 SR5 Coupe Shell. (Sold)
86 SR5 Hatch Shell
86 GT-SR5 Coupe 20v Swap
Rue
Postby Rue » Fri May 31, 2013 7:21 pm
Rumor has it that you're going to do a Beams swap... care to comment?
grappletech
Postby grappletech » Fri May 31, 2013 9:03 pm
Yea, I have the Motor and tranny at the house. My rough draft is since i have motor, tranny, extra kouki harness, spare crossmember, and a few other things. I plan to drop my 16v and have a close to turn-key drop in beams .
Unfortunately I have to go to Afghanistan so my project wont start until I return.
86 SR5 Hatch Shell
Rue
Postby Rue » Wed Jun 12, 2013 4:34 pm
New diff...
Stuck the diff in the freezer and ring gear in the oven soooooooo...
And Boston Mike is helping me with the last part for the fixture...
Rue
Postby Rue » Fri Jun 21, 2013 4:31 pm
There are a few different part numbers for the 7.5" carrier bearings. Here's the part number for the ones that work with the Kaaz diff...
I received a ton of help to get this part made. It's the last part I needed to complete the jig for the celica-supra rear end conversion.
Again... I made this fixture to match the probably 20 year old 6.7" fixture Marty at AutoComp Race Cars has. Almost finished and then we can get to building the rear ends for my car as well as Will Parson's corolla. Marty is the one who did the cage work on Will's car and is working on improving his (and my) suspension.
Aurora spherical rod ends for the lower control arms...
LCA pieces...
Marty is insisting on corner balancing my car. This means something needs to be adjustable soooooooooooo
Rue
Postby Rue » Wed Jun 26, 2013 5:08 pm
Lower control arms nearing a finish...
Garage7RP
Postby Garage7RP » Thu Jun 27, 2013 3:09 pm
What adjustment range are you trying to achieve on your LCAs?
Rue
Postby Rue » Thu Jun 27, 2013 9:01 pm
Threaded all the way in they are the same length as stock. I'm going to increase track width by 10mm per side. I'm swapping out my NCRCA's with the 60mm RCA's I machined so I will be losing 15mm per side on track width.
