CAE86 Build
CAE86 Build
Hi guys,
Thought I'd share a bit of my coupe with you.
Heres how it started about 2 years ago:
It had a pretty basic list of "mods":
Spooled diff, Buddy Club Spec 2, End links with Polyurathane bushings, stainless steel brake lines, T3 coils , Tein camber plates, Tanabe strut bar, Cross drilled and slotted rotors, Sparco Sprint 5 (Still FIA certified), Lightened flywheel, Sparco Sprint, NRG harness bar,NRG quick release. It was fun, but lacked that "wow" factor.
Fast forward 2 years and here we are:
Heres a run down of the new parts:
EXTERIOR:
Dura flex front bumper, fiberglass aero, origin rear widebody, cut and widened front fenders, made drop vent for hood and power by maxx hood spacers, neon green lexan rear windows, enkei mesh up front American racing mesh rears. Dunlop dz101 star spec fronts, dz101 rears all four 195/50-15.
INTERIOR:
FD Spec cage, sparco sprint drivers seat, buddy club passenger, corbeau purple sfi harnesses, aluminum dash and center display, apc gauges, factory fuel gauge, summitt stepper tach, nardi 370 wheel, used a Ron Francis bare bonez chassis harness and switch panel. The cell phone holder on dash is what I use for my speedometer.
ENGINE:
Silver top block, blue top head, bored to 83mm, custom head gasket, compression is around 11.5:1, je forged pistons, crank and rods where tempered, arp rod bolts, high volume oil pump, fully rotation assembly balanced, head was lightly ported, 3 angle valve job on supertech valves, toda valve springs, crower full race cams and hks cam gears, oil filter relocation and rx7 oil cooler, godspeed radiator with dual fans, custom overflow tank, mikuni phh 44mm race carbs, t3 pulley set and trigger wheel, Ford EDIS with autosport labs ignition controller, obx header, t3 test pipe to buddy club under axle with supertrapp tip, light weight flywheel and xtd stage 3 clutch.
SUSPENSION, DRIVETRAIN, BRAKES:
T3 tension arms, front suspension is custom 240sx DIY coils, 240 lca that are boxed, 240 crossdrilled rotors and calipers, I get 62 degrees of steering angle, one piece drive shaft, weir solid pinion spacer with 4.77 spooled rear end with oversized weir axels, rear trd adjustable greens, lowering 6k springs, crossdrilled rear rotors with potterfield r4s pads, steel braided lines on all four, booster delete with willwood master cylinder, cnc hydro hand brake with willwood dynalite rear braking system.
It is soooooo much fun now. Theres just a few issues I have to work out, like the EDIS system on the manifold, it likes to heat up and cut out at ~8,500 RPMS when it should go to ~9.5-10,000
Cliff notes:
This:
To this:
Then the head cracked. Swapped it out and got tired of the headaches with this motor.
I just picked up this from a buddy:
Full CA18DET swap for into an AE86. Has a lot of oil leaks and blown turbo, but the price was right. Ordered a complete gasket kit along with ARP head studs from the amazing Russell @ Nissanparts.cc today. Got half of it torn down today.
Anddddd test fitted the FMIC:
Last week I picked up a T28, Earls SS turbo lines, ACT 6 puck, DEI turbo blanket, GKTeck reclocking kit and a few other goodies. Stripped most of the CA down, getting ready to ship the head off to the machine shop.
Plans are to pretty much rebuild this motor, swap it in, and have fun next season with a reliable engine! Cant wait!
Tore it down to the block:
Then put it back together:
Right now Im finishing porting and polishing the manifolds, along with moving my rack forward to stop over centering
EXTERIOR:
INTERIOR:
ENGINE:
Cliff notes:
This:
To this:
Re: CAE86 Build
Thanks! If people are interested in this ill post a teaser pic of the new cosmetics!
Re: CAE86 Build
I fawking love this build!!!!!!!!!!!!!!!!!!!!
Re: CAE86 Build
Nice job sticking with the car bro!! Soooo many would have passed on that car and let it get junked but you revived it, great job! Keep up the good work!
Been a member here since the pop-ups were around ... Remember those, not many do!
Re: CAE86 Build
Nice build. It's good to see another CA powered AE86 on the board. What ecu/wiring are you using?
Build Thread: viewtopic.php?f=7&t=1247
Re: CAE86 Build
Thanks guys!! In regards to the harness and ecu, I'm using both stock for now, until I can afford nistune and bigger injectors lol. And yes, the CA is under appreciated! They stopped making them because they were too expensive to make.
Re: CAE86 Build
nategreat923 wrote:Thanks guys!! In regards to the harness and ecu, I'm using both stock for now, until I can afford nistune and bigger injectors lol. And yes, the CA is under appreciated! They stopped making them because they were too expensive to make.
And at the time the (racing) market demanded a more modern 2liter engine after the FJ20 was gone.
Re: CAE86 Build
Looking good! Getting close now
Re: CAE86 Build
That's a 2nd gen RX-7 oil cooler, right?
I have one myself; still need to get it mounted up though
What hose fittings do you have on the oil cooler end? I think the ports are M8 x 1.5, and I wasn't able to find any hose fittings like the ones in your picture.
Thanks!
Re: CAE86 Build
Nice!!
more more!
more more!
Re: CAE86 Build
Thanks elvin!
Re: CAE86 Build
Well got it running great yesterday, so we loaded it up for a 2 1/2 hour drive to go slide it and ended up having a coil pack go bad. Regardless, when it was running it was insane.
http://youtu.be/C2l1J_yR4Hw
Re: CAE86 Build
Car looks awesome man dig the cream and black scheme! Sucks about the coil but I know it was a blast before
