ae86 sr5 coupe revival
candamo
Postby candamo » Mon Mar 10, 2014 3:59 pm
Greetings from Lima, Peru. For the past 2 years ive been getting more competitive car wise. Had an 03 jdm sti with 300whp few suspension mods and street tires. That was all my budget could afford. If i wanted to reach get to the top places figured that i had to invest about 5grand in order to keep up with the people running full coilovers/sways/hoosiers, plus ruining what was my daily driver with a hard ride. Not possible at the moment.
Action shot!
So I thought, i should get a cheaper/lighter car, mod the hell out of it (said in my mind: ae86's must be cheap to tune... boy was I wrong). And build the ultimate street/autox car without trying to survive with noodles and tap water.
Here's the car as I bought it.
Came with 20v BT engine, upgraded front and rear disc brakes, supposedly a LSD, front and rear suspension, FRP body panels and a semi stripped interior.
Exhaust and header are a piece of #$(#$!@, made out of bent steel, corroded as it was submerged underwater before installing.
Things I've done to the car so far:
Rust repair on bad areas
Koni front strut inserts (thanks club4age)
Eibach 450lbs/8kg front springs
Haltech Sport 1000
6.7 toyota celica rear with kaaz 2 way and 4.77 rp.
FC front brake upgrade with minicooper s rotors.
Will be doing a custom 4-2-1 SS header and 2.25" exhaust.
Here some more pics of the progress so far.
Goodbye unused wiring (there was a lot more)
Ugly old brakes
Shiny new brakes
Removing all unnecessary piping.
New complete wiring harness.
Refreshed look.
Some goodies
yellowsnow4free
Re: ae86 sr5 coupe revival
Postby yellowsnow4free » Mon Mar 10, 2014 4:15 pm
Cool build! :D
I like how you've removed so much from it but it still looks like a fully functional car :)
That's a lot of wires there; what did you remove?
Good luck with your project! :)
candamo
Postby candamo » Mon Mar 10, 2014 4:40 pm
Thanks yellowsnow4free !
I removed everything but the engine harness, and lights. :)
YOTAHOLIC808
Postby YOTAHOLIC808 » Mon Mar 10, 2014 7:53 pm
Sweet starting point bro! BT Levin!! cant wait to see it all come together!
@_yotaholic
candamo
Postby candamo » Sun Mar 16, 2014 4:08 pm
Got a new (used) bucket seat.
Wiring almost done.
candamo
Postby candamo » Fri Mar 28, 2014 8:31 pm
Rear out.
Shiny is better.
Im running a Kaaz 2way with a 4.78 Weir RP fully rebuilt with new bearings and a solid spacer.
Old rusty exhaust out!
New shiny 2.25" SS and magnaflow muffler
Also noticed today that my rear spacers are assymetrical, they where like 2.5" and 2". :lol: smart panhard rod adjustability ...
candamo
Postby candamo » Fri Mar 28, 2014 9:36 pm
Pepe the welder doing his magic.
marley4us
Postby marley4us » Sat Mar 29, 2014 12:09 pm
Where did you find the kaaz lsd for the ma47 celica supra rearend? Also how much was it? I have been looking for one for a minute.
1994 4runner (The truck)
candamo
Postby candamo » Sat Mar 29, 2014 12:38 pm
its from an early 81 celica with a 6.7" rear end and zenki axles.
marley4us
Postby marley4us » Sat Mar 29, 2014 12:51 pm
ohhh, I miss read, I thought it was from a MA47 celica supra 7.5 ones.
Postby yoshimitsuspeed » Sun Mar 30, 2014 3:34 pm
Nice project
candamo wrote:So I thought, i should get a cheaper/lighter car, mod the hell out of it (said in my mind: ae86's must be cheap to tune... boy was I wrong)
How so?
There is quite a lot of good bang for the buck products for the 4AGE and AE86.
yellowsnow4free
Postby yellowsnow4free » Sun Mar 30, 2014 4:05 pm
candamo wrote:Rear out.
candamo wrote:its from an early 81 celica with a 6.7" rear end and zenki axles.
So the rear axle housing is from an early 1981 Celica? If so, I thought those didn't come with rear disc brakes... are you using an adapter? Also, when you said "zenki axles" are you referring to zenki AE86 axles?
Sorry for all the questions, but I've been looking online for days for AE86 rear end options :P
candamo
Postby candamo » Tue Apr 01, 2014 1:38 pm
You are right yellowsnow, the axle housing came with drums however I swapped my disc brakes from my older setup which has ae101 solid rear brakes.
Regarding the axles, what i meant is the size of the spline. I guess they are the same as the AE86 zenki since thats what my rear lsd is for.
yellowsnow4free
Postby yellowsnow4free » Tue Apr 01, 2014 6:27 pm
candamo wrote:You are right yellowsnow, the axle housing came with drums however I swapped my disc brakes from my older setup which has ae101 solid rear brakes.
Thanks for the info :)
I've been searching for an OEM bolt-on solution to convert my SR5 rear end to disc brakes. Looks like a lot of Toyotas have that same axle flange.
Did North American AE101's have rear disc brakes?
candamo
Postby candamo » Wed Apr 02, 2014 5:43 pm
The rear calipers and disks are from a Levin AE101, i believe thats only JDM model.
Today I installed the KYB AGX rears with TRD 6kg springs.
The local AutoX tournament starts this sunday. So wish me luck :mrgreen:
yellowsnow4free
Postby yellowsnow4free » Wed Apr 02, 2014 6:28 pm
candamo wrote:The rear calipers and disks are from a Levin AE101, i believe thats only JDM model.
Ah, kk.
That means I have yet to find a bolt-on brake option using parts from the US :P Oh well :)
Good luck with autox on Sunday! :)
redbeltpanda
Postby redbeltpanda » Wed Apr 02, 2014 9:09 pm
Good differential info & nice rolla
candamo
Postby candamo » Sun Apr 13, 2014 1:40 pm
yoshimitsuspeed wrote:How so?
Well, the car is pretty old and it needs a lot of stuff in order to keep up with younger, higher powered cars. Also have to fix rust and paint...
Last weekend was good and bad.
Threw the car to the dyno to dial in the new ecu. After a couple of hours tuning it ended up with 128rwhp and 100ft/lbs tq
Got the car out of the shop and while driving to my house the drain plug from the rearend fell and when i got to my house it was out of oil :o :( . Its whining badly right now, so i will take it a part, check the damage and see what am I going to do.
Regarding the autoX event. Placed 5th out of 130 cars 8-) . And only one in the top10 without full slicks.
Heres my best pass from the event.
http://youtu.be/NICQJNPzL1g
candamo
Postby candamo » Sat May 17, 2014 6:10 pm
A little update from what has been done the past month.
SQ Cooling kit for the 20v. Great support and an awesome product all the way from AU. Now water temp wont go down on the highway, and it doesnt take 2 hours to warm up. Checked that out of the list.
A little before and after action. (after and before actually)
Next an oil cooler was installed. Its actually a Mishimoto kit for a Hyundai Genesis thats worth about 550$ and got it for 100$ almost brand new. Ordered a thermostatic oil sandwich and voila! it fits!
Then I was browsing the local classifieds and found a couple of jewels. Two TRD Tosco 13x9 wheels with the 230/50 original Dunlop tires in pretty good condition.
N-86 tires. Sweet hehe!
And they fit quite well without spacers. However need to run at least 5mm spacer to clear the brakes.
Sitting next to a JDM Spec C fully built and converted to LHD.
Those are two sexy rear ends :P
Wondering around town saw Colin McRae (RIP) reborn as a moto taxi driver.
And to finish it up a little less weight with lexan windows and an alignment.
candamo
Postby candamo » Mon May 19, 2014 10:17 am
A video from the event yesterday. Wasnt able to push too much since running out of that track means breaking tons of stuff. My brakes are way too sensitive and its very hard to stop fast and late without locking up. Will have to do something about that. Im thinking upping the MC to 1" from 13/16 and adding a brake bias adjuster.
https://www.youtube.com/watch?v=h7nnQZK7Yz0
candamo
Postby candamo » Tue Jun 24, 2014 2:33 pm
Some more updates.
I had to cut the floor since I wasnt in a very comfortable position.
Welded a new floor and the seat bases.
Also started to make custom headers.
It touches the brake lines and clears the VVT solenoid for about 1cm. Hope it doesnt melt hehe. Also will wrap the headers with some thermal tape and go booster-less with a 1" MC instead of the 15/16" im running at the moment.
Scarecrow
Postby Scarecrow » Tue Aug 26, 2014 8:13 am
Wow!
Awesome - Can't believe you found those TRD / Tosco's!
candamo
Postby candamo » Sat Sep 27, 2014 7:38 pm
Scarecrow wrote:Wow!
Yeah and they where like 300$ hehe. The only problem is that I havent been able to find tires locally and they are now part of my room decoration :lol:
Updating the thread a bit:
The header experiment wasnt succesful, hp and torque dropped a bit and the primary of the 1st cylinder is touching the vvt solenoid which now is clicking like a SOB.
Replaced the cheap ebay heims from the 4 links with QA1 aluminum heims and added traction brackets and now I feel that im driving a rolls royce. Now the rear is much more compliant and stopped sounding like a cheap motel bed.
Got rid of the old radiator that was leaking everywhere with a Mishimoto Civic aluminum rad.
Painted the interior.
And made a surge tank since the sr5 tank has no baffles and I had to run it with 3/4 tank for not having fuel problems.
Ready for AutoX action tomorrow!!
JyuRoku
Postby JyuRoku » Mon Sep 29, 2014 2:47 am
no problems with the cooling kit so far? mine initially cooled too much, swapped for a non-drilled thermostat and it fixed it. now my coolant temp floats up and down... :-(
candamo
Postby candamo » Tue Sep 30, 2014 7:35 pm
JyuRoku wrote:no problems with the cooling kit so far? mine initially cooled too much, swapped for a non-drilled thermostat and it fixed it. now my coolant temp floats up and down... :-(
I have a bit of an issue with the temperature getting to 105C for 3 or 4 secs and then stabilizes back to 90C. However i think that could be from my leaking mishimoto radiator cap.
Also the coolant on the ae86 is very tricky to purge. At least for me. I had to get one of those kits that has a funnel bolted to the radiator cap and thats how I got rid of all the air pockets inside.
grappletech
Postby grappletech » Tue Sep 30, 2014 8:50 pm
For getting rid of the air I get something to make the fluid higher than the engine. The gravity will force the fluid down and the air will rise. I usually do it with a Gatorade bottle with the bottom cut off and electrical tape around the top , jam it in and go!
87 SR5 Coupe Shell. (Sold)
86 SR5 Hatch Shell
86 GT-SR5 Coupe 20v Swap
candamo
Postby candamo » Fri Nov 14, 2014 7:09 pm
Got a new head for the new motor thats going in.
Can anyone guess?
candamo
Postby candamo » Thu Nov 20, 2014 9:37 am
This years autox championship is almost over. Have to get at least 3rd in the last event in order to secure my 1st place overall. :)
Motorwise, I was debating on keeping the 4AGE 20v, however, havent seen many reliable 150WHP+ 4AGEs around. And in order to get that power the investment is quite higher as getting another engine with more displacement.
So I got myself a SR20DET block and gearbox and a SR20VE head. Will be building this puppy and stick N/A. According to the internetz can easily achieve 180WHP+ without too much hassle.
Regarding the rear end Im thinking on going for the Weir SC turbo axles.
Anyone knows if the 2 piece driveshaft can handle that power?
candamo
Postby candamo » Fri Dec 12, 2014 6:59 pm
This years season is over. At the beginning the competition wasnt so feirce, I was able to get the first 2 events easily. The car feather weight allowed me to maneuver between the cones in the kart track without a hitch, nothing like the big cars which under steered like crazy.
Then I put the roll cage and headers. This **** really fucked up the car :twisted: :twisted: . First the headers were too big for the stock engine. Lost like 8hp and 10tq. Add in the extra weight from the cage and the result is a slower and less competitive car. F$CK.
Ran all year like this and suffered on the big track which has a big 500 feet low incline climb.
Ended up loosing the next 2 events to an 07 Civic SI with a bunch of mods and hoosier A6s. Im running hankook z214 C51 compound which stinks for autocross since they never get up to temp.
The last event was held on the Kart track and I had to get at least 4th place to win the championship. The month the final before was my poorest performance so far. Came up 4th beaten by my buddies Starlet KP with a built 16v which goes like hell, Civic SI and a VW bug. :oops:
I made sure everything was perfect and all the effort was rewarded. 1st place on the last event and the championship :mrgreen: .
Now time for more powah.
Engine out and some help from my friend Rhino.
Then I hitched a ride to the fabricator.
New powerplant with the patient.
This is how it sits today. Im thinking on moving it a bit farther inside
candamo
Postby candamo » Thu Dec 18, 2014 5:43 pm
Engine and gearbox are in.
Didnt use spacers on the crossmember and clearances are very tigth down there. I might have to put a skidpad just in case.
As I said, engine is quite far back lol.
Enginen will be rebuilt with 12.5 CR pistons, and stock valve train for the moment. (stock SR20VE cams are 264 10.7 in 268 10.3 ex). Hoping to get around 170-180 to the wheels.
