This is my 2nd 86, first was written off...
I have a running build log over on another local forum but thought I would share over here at Club4AG.
Just photos on this first post!
 but I have to wait till oct
 but I have to wait till octSapporokid wrote:Is that a rx7/ae86 rear diffuser?
looks very nice! love that beams haha
YOTAHOLIC808 wrote:Any vids of it running? ~ Looks amazing! good work!
Oni-Roku wrote:Oh man.....makes me want to build my ae86 so badbut I have to wait till oct
 Where is a drooling emoticon when I need it?
 Where is a drooling emoticon when I need it?LongGrain wrote:What adapter did you use for your quads? Xcessive? If so did the itg plate bolt right on?
Clouds wrote:It's sooooooo nice!Where is a drooling emoticon when I need it?
lootbag wrote:LongGrain wrote:What adapter did you use for your quads? Xcessive? If so did the itg plate bolt right on?
Xcessive yes, and the ITG plate from SQ did work but I ended up taking off those quick release fasteners and using bolts and nuts to secure the two together.
Slightly sanded down edges to make the fit tighter as well.
Your BEAMS86 is pretty rad by the way!
LongGrain wrote:Cool, thanks. I was curious because the ITB spacing with the xcessive adapater is a little different than it is on the 20v, so I wasnt sure if the bolt holes would all line up perfect.
Toy86 wrote:Great Beams swap, and great looking 86! One question, how wide are the rims you running? Also, why did you chop up ur rear bumper for? Thanks and good luck on ur following track days!
lootbag wrote:Installed the CUSCO front radius bar... loks nice
ae86714 wrote:Pretty sure this is incorrectly installed...
 My mistake, I was thinking it was supposed to attach to the ends of the tension rods like some other styles I've seen.  And now looking at the bends in the cusco bar, it doesn't even look possible to attach the way i was thinking.
 My mistake, I was thinking it was supposed to attach to the ends of the tension rods like some other styles I've seen.  And now looking at the bends in the cusco bar, it doesn't even look possible to attach the way i was thinking.ae86714 wrote::oops: My mistake, I was thinking it was supposed to attach to the ends of the tension rods like some other styles I've seen. And now looking at the bends in the cusco bar, it doesn't even look possible to attach the way i was thinking.
GTS_007 wrote:what kind of wing is that ?
