After looking at the chiltons and figuring out how to wire everything up, I set the relays out and started the process of wiring it all up.
Once it was all wired up, I set to connecting it all in the car. I quickly hit a snag in that I had no ground to my high beam trigger when the switch was pressed forward. After a little bit of troubleshooting I found that the steering column assembly switch was not making contact when it was supposed to.
I bent the top contact out of the way and added a solder bead to the switch contact.
Once that was taken care of, I added some sealing gum to make sure I had a solid seal on the headlights with the HID.
Next I just added the wires to the existing factory harness so I could go back to stock if needed and fired them up. Great looking in the garage but still need to take them for a test drive here at night.
Im looking into replacing the front LCA, TC rod and tie rod ends with T3 stuff but not sure if I'm ready to get that all done before getting the car painted. Hopefully, I can afford to do both in the near future.
